What wood to use for a guitar?
>My brother got the music gene. I did not. He wants to make a guitar. I got the wood working gene. He did not. He wants to know what local wood, local to southside Virginia could be used to make a guitar. We own a farm that has some hardwood forest on it and he is considering cutting some trees for the purpose of making a Guitar. I have no desire to make one and it seems it would be better to buy a kit or in my case just buy a guitar. So, what trees should we doom for this project?
Re: What wood to use for a guitar?
Ken Oakley-Sunny St. Cloud, Fla.
>Dan Donaldson is probably your man on this subject. He is always posting thing concerning stringed instruments. Walnut is good for the sides and probably for the back. Read someplace that Sitka Spruce is the best for the top. Again, Dan's the man.
>I read an old article in FWW where sassafras was found to have wonderful properties for sound, in that case for a dulcimer. I've never heard of it used for a guitar. It is fairly coarse wood but machines beautifully. I've been turning some on the lathe.
Bruce, a MN Galoot
>If red spruce grows on your land, it's a very highly prized wood for tops.
Bruce
Dale Lenz
Re: Not Dan by any means... *LINK*
Dale Lenz
>but the link below might be something to fret over, beat that one, Col., : ' >. Bet you can without trying to hard.
Guitar Woods
Check out the MIMF *LINK*
Phil Joines in Krum, Tx
>They have tons of information on making gittrs. What kind does he want to make? There's probably 10 kinds and they all have different requirements.
Music Instrument Makers Forum
Paul Woolson
>I don't post here a whole lot but lurk often.
I'm a full time guitar builder. That's my trade/craft/business.
I'm not familiar with what woods are in the area of the US you speak of but I'll do my best to give you some advice.
For the back and sides, you'll want something hard and light weight. I realize those two don't often go together. Many local woods can be used but are just "OK" for sound transmission. Walnut can work as can cherry. Oak is actually a really nice tonewood, It's just pretty boring to look at.
For neck wood, mahogany is the old stand-by. Spanish cedar is becoming a very popular substitute. But there's no reason that walnut or cherry wouldn't work here as well.
Tops on the other hand: you don't have many options here. Spruce, Cedar or some of the softer hardwoods (mahogany, koa, some very soft walnut). As said above, Adi Spruce is highly praised, though very hard to find in high quality pieces big enough for a two piece top. There are literally dozens of spruce species and they will all make a fine top.
Sources of info:
MIMF.com
Luthiersforum.com
"Guitarmaking: tradition and technology" by Cumpiano/Natelson
Let me know if I can answer any specific questions.
Good luck!!!
Joanne in Pt. Pleasant, PA
>Some good answers and links here already, but you do not specify whether he wants to build a steel string acoustic, a classical acoustic, or a solid-body electric guitar. I think most of the answers have assumed the first. If he is particular about sound and tone, he should go play/listen to guitars built of different woods to listen for what tone he likes. A spruce top with rosewood sides and back will sound different from a cedar top with mahogany sides, etc. You will not find those growing locally, but there are some local woods that will be similar in grain, density, and tonal qualities that will work.
What type of guitar?
>While there is some overlap in woods used, hollow-body accoustic guitars use different woods that solid-body electric guitars, especially in the body. Even in accoustic guitars, there are differences between nylon-stringed classical guitars and steel stringed accoustic guitars.
What sort of guitar does your brother want?
Having built a solid body electric guitar, I'd say an electric guitar is easier to build.
Happy Woodworking!
David C. Lykins - Dallas GA - guitardude
>Robert Bennedetto whom is the highest paid luthier I know of @ $20,000 a guitar actually made one out of pine. In short if he's wanting to build an accoustic, dobro, archtop guitar wood choice is important as tonal quality varies with species. I general somthing like Mahogany has a warmer/deeper tone than rosewood, and MOST Accoustics and Archtops have either a spruce or fur top. As others have suggested the MIMF is a GREAT place to start, also if you haven't seen Paul Woolsons work and picked his brain about this, he builds awesome guitars and has a wealth of knowledge....I wish he was my neighbor.......LOL.
One thing that you may want to consider an no one has adressed it yet is that building a guitar requires a slew of specialized tools so unless he's going to have some one bend the sides, radius the fingerboard and install the frets He'll need to purchase specific tools to do so, especially for radiusing the fingerboard and installing frets. These three phases of guitar building can require very pricey tools to do it right, and may not be worth the expendature if he's only going to build one or two guitars. You could get by with steaming the sides and placing them in a home made mold, and I'd highly reccomend purchasing a pre-radiused fingerboard from STuMac or LMI. My first tool order to build my first scratch built guitar was $800+. Working on scratch buit guitars 5 & 6 and praying they play better than the first three.
Just MHO.
Good luck, and let us know if we can help
