>I have a crotch from a birch tree that was cut into a block and allowed to dry for about three years. I have sawed some slices from it and made some veneer. The pieces are about 8 X 12. I have not measured the thickness, but it is under a 1/16" I intend to laminate this to a piece of 1/4" oak plywood I happened to have and use it as the top for a box. I was going to laminate a slightly less desirable piece from the same blank to the other side for balance. It occurred to me I could sand the oak face off the plywood and replace it with the birch. Would that work? More curious than anything else.
Two part response here... First, why do you want to sand the oak off? Is it a question of total thickness??
Second, it should work, but my concern would be that you will be introducing a lot of moisture to a relatively thin substrate, which might cause some warping. Be sure to do both sides at the same time and keep it clamped or in a press until its thoroughly dry.
>I was thinking that it would then have a single piece of veneer on each side and would be "balanced".
I just tried to salvage a piece I did a couple of years ago. I had put some Black Gum Burl on one side of a piece of 1/4" Luan plywood. It warped about every way it could. So, I laminated a piece of the birch crotch on the other side. Just took it out of the clamps after about an hour. Boy does it have an arch in it. Piece is about a foot long and must have 3/8" of arch. Should I have left it longer? Or was this destined to fail any way?
>It's not hopeless, Barry, but it's unpredictable. The reason the panel is cupping is that the internal stress that was cupping your original lamination is still there. Just adding a veneer to the opposite side won't hold it flat once you remove the clamps.
One-sided (unbalanced) constructions move (cup, bow, twist, etc.) because of unrestrained wood movement of the substrate and/or differential movement of the face veneer. This has to do with the moisture content of the component layers changing. If you wanted to salvage the piece, what I would have done is to try to equalize the moisture by misting the cupped side with water, to try to flatten out the cup. This will relieve the internal stress, so that when you add the balancing veneer, it doesn't have to work so hard to keep the panel flat. Note, I have never attempted this because I've always been very strict about balancing veneer jobs. Theoretically, I believe my fix would work.
One other thing: It's always a good idea to make your panels of a thickness that works with the overall construction of the piece. If the panel will be self-contained, i.e., unrestrained by a frame or other structure, it needs to be thick and stable enough to stay flat in that situation. To an extent this also depends on the core material. Lumber cores and veneer cores are not as stable as MDF cores, but MDF has the unfortunate property of wanting to sag if it is not adequately and evenly supported. It also absorbs moisture at the edges, so you have to be meticulous about sealing and/or enclosing them. Edgebanding works well for this.
If the panel will be enclosed in a frame, it probably won't matter much if the panel is slightly cupped, as long as the frame is of adequate thickness and strength to hold it flat. People sometimes get into trouble when they enclose a veneered (or solid) panel in a frame that is not stiff enough to resist the panel's cupping stresses, and the whole door or whatever warps.
