Steam UN-bending- "saving the day"
Bill Tindall, E.TN
>When I made the French-footed Federal wall cabinet I posted a while back I had a very limited supply of 16/4 real mahogany from which to make it. Upon resawing pieces for the cabinet sides two of them bowed, a lot. Rapid bowing after resawing is the result of stress induced in drying, not an uncommon problem when drying very thick lumber. I had to figure out some way to use this lumber because I had no other.
The only way to change the shape of lumber once it is dry is to steam it. So the problem became, how could I steam these large pieces and force them back straight. Necessity became the mother of invention. The picture shows the arrangement that resulting in taking the bow out of the resawed pieces.
First I flattened a thick piece of oak shown at the bottom in the PIC. I placed three sticks on the flat oak surface, one 3/4 x 3/4 to align with the near end of the mahogany piece, a 1 x 1" thicker piece in the middle and a second 3/4 x 3/4 at the far end. One 3/4 x 3/4 is show in the foreground. Next the mahogany board was supported on these sticks, bow up. The mahogany board was then clamped flat against the sticks as show in the PIC. The thicker stick in the middle provided tension opposed to the bow of the mahogany board, ie. the clamps and sticks put a bow in the board opposite of the bow the board had acquired after resawing.
Next, several layers of soggy wet cloth were placed on the board and the cloth steamed with the steam iron, as shown. The steam plasticized the wood allowing the tension provide by the clamping arrangement to straighten the board. I arbitrarily steamed (while adding lots of water to make the steam) for 10 minutes and then set the clamped piece aside to cool and dry. After two days I removed the clamps and found that nearly all the original bow had been straightened. The second board I steamed for a bit longer and it came out dead straight. Wooohooo! I was pleased.
Note, lots of red colorant bled from the mahogany, coloring the cloth (no problem) and baking on the iron (a wife issue to be fixed upon finishing the project).
