flat bottom saw kerf
Newt Carlson
>Can anyone recommend a 10" saw blade that will cut with a flat bottom kerf? I am trying to make some cleaner box joints and need a blade that leaves the bottom of the grove flat. I want to use the table saw for this and not a router table. My dado blades don't work very well for this process either.
Re: flat bottom saw kerf
Ken Bellock (Houston, TX)
>I have a Forrest 10" blade with a #1 grind (flat bottom). Works fantastic.
Ken
Re: flat bottom saw kerf *LINK*
Andy Lincoln,in Dearborn,MI
>Newt,
freud (and others) make a pair of blades taht are specifically for box joints>The Freud will make either 1/4" or 3/8" joints depending omn how you stack the two blades.They are very flat in my experience.
I also believe Forrest will grind a blade to cut flat bottoms if you need the joints to be 1/8".See the link below to a google shopping page for info on the Freud.
Andy
Freud on Google search
Thanks for the help.
Newt Carlson
>Many rip blades leave a flat bottom kerf. Check yours and see what you have. Might work.
Ray Newman
>I had the same problem w/ my dado set.
Mentioned it to the sharpening shop & was told it was a common problem & the blades need to be re-ground to the same dia. Call a few sharpening services. It might be cheaper than buyng a new saw blade or the dedicated 1/4" & 3/8" box joint blades.
Had it done & they now cut a flat bottom. Next time you have the dado set sharpened, ask them about this. You'll need to have the entire set sharpened ea. time so as to main the same dia.
Howard Acheson
>Full kerf 24 tooth rip blades typically have flat cut teeth. These blades are a lot less expensive than a custom ground Forrest.
What Ken B said
NickTuzzolino
>I also use the Forrest Special #1 OD grind, 40 tooth, WWII blade. For cutting exposed splines on jewelry boxes, etc, it makes a flawless cut.
Jim Dillon
>Newt,
I'll third what Ken and Nick said regarding the Forrest custom FTG 40 tooth blade. I got the recommendation from Yeung Chan's book where he uses it for fine joint cutting. I've had it for roughly three years and couldn't be happier. It also helps to use a sacrificial backer board when cutting finger/box joints etc.
Jim
I attended one of Yeung Chan's demo's...
>That's where I got the idea to use a rip blade. Maybe he was being creative and using what he could get, but it worked for him.
Re: Ridge Carbide TS2000
pecker
Re: I attended one of Yeung Chan's demo's...
Jim Dillon
>Hi Barry,
I'm envious of your attendance at Chan's demo. I REALLY like his power tool book, as well as his Krenov inspired crafts. I wish he would also do a book on using hand tools - for us mere mortals.
Jim
