OT: I give up on Firefox (rant)
Pat Evans
>The subject of Firefox running slow has come up before and it seems there are always numerous suggested fixes. Some work for a short while, but none seem to correct an obvious problem. I'm now using IE because Firefox has gotten too slow to use and I'm tired of experimenting with fixes. Seems as if the writers of Firefox are beginning to become more like Microsoft.
Re: OT: I give up on Firefox (rant)
Dan Donaldson
>Something is weird about your setup. FF works fine for me on Windows or Linux. Too bad it doesn't work for you.
>Which version are you using? Have you installed any addons? (I use none)
Does a reboot temporarily fix it? If so, when it slows down look at the processes before and after in Task Manager and make sure nothing funny is going on (such as orphan copies of acrobat that didn't get closed.)
On hearing of some problems, I declined the upgrade to version 3 and I have no slowdown problems. The only problem I've had is hanging on my 401k web site (sure am glad I got out of the stock market earlier this year!) so I use IE for that.
If you are using 3, is it possible to reinstall 2?
Chuck W
>I am using the latest version with no problems at all. It sounds like there is something else running in the background on your computer that could slow things down. What is your setup?
I'm with the rest (so far)
Rod Peterson -- Ormond Beach
>I have it running on three XP machines and one Linux machine. I couldn't be happier. The only problems I ever run into are websites stupidly coded with m$ software to only run on infernal exploder browsers (clueless developers), or when I've had twenty or thirty tabs open in two or three browser sessions for two or three weeks. Hard to blame that on Firefox.
I code all of my web stuff to run on FF. I'll take a look with ie6, but if it's reasonably close won't even bother writing hacks for it. I don't even bother with ie7.
Has to be something on your computer.
Rod
Howard Acheson
>I have been running Firefox for a couple of years with no problems or slow down whatsoever. I've applied all updates as they have been released.
Pat Evans
>John, I'm using V3.0.4. with only Adobe Acrobat and Shockwave Flash addons, both of which are disabled. I'd have to do some research, but I think I remember reading that going back a version had some problems. A reboot doesn't fix it and I haven't found any odd processes running. It has gotten now to where rather than just slow, it eventually gives me a page not found error when I click on a link.
Pat Evans
>Chuck, I'm running Windows 2000 on an Inspiron 8100. (Yeah... I know. It's ancient, obsolete, and all that.) Still works though. Mostly.
Pat Evans
>Yeah, it is too bad. I much prefer Firefox when it works, but the more I use it the slower it gets. I have read on the Mozilla support forum where others have the same problem, but no fix seems to permanently cure it. Of course, if I knew anything about computers it might be easier to understand and implement fixes.
Get rid of your add-ons
Rick Christopherson
>After I had switched over to Firefox from Netscape, it began to slow down to an irritating crawl. So when I loaded a clean copy to upgrade from a previous version, I disabled all of the crap I had added to the previous version. It was a world of difference.
It is not Firefox that is slow, but all of the easily installed add-ons. Uninstall them!!!!
Firefox fixes...
Chuck W
>Pat,
What have you tried in the way of fixes to make firefox run at a decent speed? The onl thing that comes to mind is maybe something dell has installed on the laptop, an application or something like that. How much memory does you laptop have? It may be as simple as upgrading the memory which is not expensive to do.
The other thing to check is open task manager and see how many processes are running, do this when you boot up the computer and then after firefox becomes slow. there is a process that is hogging cpu power.
>You might also have some spyware or maware running in the background. Those things are famous for slowing browsers, although I would think that they would affect all browsers, not just Firefox.
I must be lucky, but I'm using Firefox on all my computers and it works just fine. The only time I get a page not found is when my DSL craps out. You might want to check your connection.
Ronald from NW Ohio
>I use safari and i love it. Easy and fast!!!
