alternative to cloth-back vinyl?
Ken Platt (granby, CT)
>Folks - I'm making a small doohickey to hold desk type items. The project was in Wood Magazine, and they called it a "dresser-top valet".
The plans call for using something called "cloth-backed vinyl" to cover a small panel on top (I've scanned the picture from the magazine and posted it). I think the point of having this stuff there is so that things won't slide around on the top, and to be a soft surface so you could put things there without damaging them or the surface.
Anyhow, I'm having trouble finding this stuff (although it probably doesn't help that I don't really know what it is). So I'm looking for suggestions on alternatives. The nearest fabric store is 30 miles, so it's not terribly easy to just go looking; I'd rather order online if I knew more about what I'd be getting.
So, any suggestions? Leather, suede, or some other material? Maybe one of those little flocking devices? Many thanks -
Ken
Re: alternative to cloth-back vinyl?
Robert Lemon
>The cloth backed vinyl is similar to naugahyde. You can use almost any type of material you want. A shop that recovers auto tops might have something for you. Walmart has fabrics. Leather is good. Craft stores might have some goods also. Good Luck.
Dan Donaldson
>I would use leather. There are a lot of places where you can buy scraps that might be big enough. Just do a google search.
>I like the idea of leather, too. It can be stretched a little and glued to a flat surface. We have a Tandy Leather store here with a huge variety to pick through. Deer skin is nice. Sometimes deer meat processors have a side business selling tanned leather when the customer doesn't want the hide.
Charles Yawn
>Ken, while reading your message, I thought about flocking, too. I have used the kits for the inside of boxes; however, I believe the stuff would not work on top of your valet. You would not anywhere near the thickness of the other materials mentioned and the flocking would probably abrade or flake off easily. Charles
Ultrasuede
GalenV
>You have shown the shape you are using for your doohicky, as you call it, but not what wood. The leather and cloth back vinyl are all very good. As for flocking and anything with a softer surface they just tend to be hard to keep clean from dust and pocket "collections" and show abrasion.
Not wanting to travel 30 miles is limiting for materials for such a small area. Maybe I make too many trips across town.
Closed weave cane would add a different look but it will trap dust.
Denim would add a look to the right wood for a guy.
Colored glass would work as long as you do not throw down heavy keys.
It's the lower part of my boots I wear out not the top and I have used the leather for small projects since it looked like new and for what they cost nice to know it had one last use.
I save too much junk!
Supplier for small pieces of leather?
>Dan, if you know any suppliers for small amounts, I'd love to hear. I tried to find one, but either I can't search well or I just couldn't find them in the long list of suppliers, pretty much all of which only listed buying full hides. One did have a "scraps" box, but I was worried there wouldn't be large enough pieces - I'll need about a square foot, 4 pieces that size. Thanks -
Ken
Naugahyde looks good
>Robert, thanks. Naugahyde looks like it might be just the thing, and I found an online supplier who was willing to send some samples. The range of colors and textures is impressive. I'll still have to get at least one yard in length, but it's only mid-$20's for that amount.
And apparently it was invented right here in Connecticut. The stuff one learns.
Ken
>John, what has to be done to the skin to make it usable? I have a friend with a deer hanging in his yard right now....I don't know if he uses the skin. He said he is letting it "mellow" before butchering it.
I also like the idea of leather, but as I'd posted, I couldn't find a supplier for small amounts. If you know of one, I'd appreciate hearing.
Thanks - Ken
See if you've got a Tandy leather dealer nearby
Bill Houghton, overcast in Sebastopol, CA
>they used to sell small scraps and less than full hides. You may something of a premium for the convenience, though.
deer hide *LINK*
>A hide must be properly tanned, a chemical and physical process which makes it supple. Check "tanning" on Wikipedia for details. The hair is often removed as well. You can do all this yourself (probably plenty of instruction on the internet) - people have been tanning hides for many thousands of years. However, a simpler way is to have someone do it who specializes in leather processing. Many years ago when I did a little deer murdering, I paid a little extra to the deer meat processing business who sent the one hide off for tanning.
Mine came back in about a month in perfect condition, but I did read here once that in some areas the ticks are so bad that some deer hides have hundreds of scars which may not make it as useful. Perhaps you can tell by inspecting the neighbor's deer.
You can order from a huge variety of leathers at the Tandy Leather web site. It would not be as good as looking through the stock at the store, but they have a good reputation. Also ask around - I was at the farmer's co-op last winter when a guy with a little knick-knack shop was describing the big shipment of hides he just got in for resale.
Do you have a garment or upholstery shop in your area? I bought small pieces of leather from a craft store once when rebuilding a player piano. (For valves and gaskets)
http://www.tandyleatherfactory.com/
GalenV
>Ken
We still have people around that do furniture upholstery or even furniture restoration that may have leather or cloth back vinyl pieces. You may find an automative upholstery shop as well.
Just places you might find they will sell drop or small pieces.
Not sure what you may find close to you.
Tandy about 45 minutes away
>Turns out they have a dealer in East Hartford. I've emailed to see whether they sell smallish pieces. Thanks, Bill.
Ken
What size do you need?
>And what color? My wife has bought a few leather coats at yard sales to use for making teddy bear feet. I might be able to find a piece suitable for your project if I dare open up her sewing closet ;)
Happy Woodworking!
