Painting a concrete floor question
Nat Robison
>The floor in my basement laundry room is currently a very unappealing gray. I'd like to paint the floor to lighten it up. Since I can't exactly open the windows for ventilation right now, oil-based is out.
Is there any potential downside to painting a concrete floor with latex and covering it with 3-4 coats of water-based poly??
Re: Painting a concrete floor question
>They do make rather resistant latex floor paints. Some of them are "fortified with epoxy fibers".
However, just because you are using latex or waterbased poly, doesn't mean that solvent vapors aren't present. They just aren't mineral spirits or naptha. Some of the alcohols, ethers, glycol ethers are just as nasty to the health as what you would find in oil based paint. Think about ventilating your space anyway. BTW, they can also be somewhat flammable.
Tony - Memphis
>I used some water based floor and deck type paint to cover up some thresholds and it has held up very well. I'd be concerned about it sticking well to whatever is there now, but you could try a small patch and see. I just bought some Behr from HD on a whim, but it has held up very well.
Tony
Dave Anderson (PacNW)
>Use water based epoxy garage floor paint. Follow directions to the letter
Alex Grigoriev
>Water-based epoxy smells obnoxions, too. Use a vapor mask and good ventilation, too.
Behr Water Borne One Part Epoxy
>Marketed as a garage floor paint. Many colors and can be tinted. No odor; water cleanup. Easy to apply and is plenty tough.
Clint
