Gooey BLO
Gooey BLO
Gooey BLO
Ken Krawford
>I applied a second coat of BLO yesterday to a piece I am finishing. When I looked at it this morning I noticed several small areas where the oil had congealed and was starting to dry. I tried just rubbing it out but little globs of the finish adhered.
Is there a solvent I can use to remove this stuff or another approach that would be better?
Thanks.
Re: Gooey BLO
Re: Gooey BLO
Bill White
>How old is your BLO?
Bill
Re: Gooey BLO
Naptha
>Then throw out the rest of the BLO. If you want a drying oil finish, use a tung oil based concoction that does not contain BLO.
Clint
Re: Gooey BLO
Re: Gooey BLO
Howard Acheson
>It sounds like you have applied too much BLO. You should apply, let set for 15-30 minutes and then wipe the excess dry. Let that dry overnight and then do it again being sure to wipe up the excess.
At this point, use mineral spirits (naphtha dries too fast) and 3/0 steel wool. Rub the mineral spirits in moving the the direction of the grain. Use lots of paper towels to wipe up and dry the surface. Let it dry overnight.
What were you planning to do next?
Re: Gooey BLO
Next
Ken Krawford
>I'll be applying some Sealcoat tinted with Transtint.
Re: Gooey BLO
Re: Next
Howard Acheson
>Applying more than one application of BLO is not necessary if you are going to be applying a topcoat. You'll get no more coloring and it will just take longer for the BLO to cure.
Re: Gooey BLO
Re: Next - FWIW
Ken Platt (granby, CT)
>For what it's worth, on my most recent project, a white oak bed, I too used transtint-colored sealcoat for the finish. In my finish testing, I tried it with and without an initial coat of BLO, and couldn't tell the difference.
Ken
Re: Gooey BLO
A twofer gloat there?
Bill Houghton, overcast in Sebastopol, CA
>Nice bed, and your client looks like a sweetie.
