Need Hardware for toilet compartments
lee beeden
>I've been asked by the local hotel to build 5 toilet compartments for the ladies. They want something a little different from the normal generic metal compartments.
I'm going to build something thats frame and panel using plywood( 3/4" vertical grain mdf core) as the panels and solid wood as the frames. The main frame will be 3 X 3s out of fir.
Looks like the doors will be 1 1/4" to house the 3/4' panels also.
I'm looking for a hardware supplier for the hinges and locking mechanism.
Any suggestions or comments about this project very much appreciated.
lee
Re: Need Hardware for toilet compartments
My standard answer . . .
steve mackay
>" Why Lee Valley, of course ! " Might pay a bit more but it'll stand up to "industrial" use.
Sounds like a can of worms
>I don't usually start a post with that kind of subject line, but being a veteran of thousands of restrooms in as many places, I'm suspicious of a wood solution to the stall problem. Stalls are a magnet for graffiti, for one thing, and normal janitorial routine subjects your uprights to water and disinfectants forever.
This is not something that has ever come up here, as far as I can recall, but it is worthy of further discussion.
Scott in Douglassville, PA
>You mean like this?
That was weird...
>...after posting the above, I closed IE, and about 30 new windows opened to WC. Couldn't close 'em fast enough - had to kill the computer...
Bill Houghton, overcast in Sebastopol, CA
>I'm with Ellis.
I haven't spent much time in women's restrooms (only when I was briefly in the trades, and even more briefly pushed a broom as a custodian), so I don't know how big the grafitti problem is, but there's always moisture - I wouldn't expect wood to last long without major constant maintenance.
Our local University has been experimenting with panels of what looks like Corian. The panels are quite attractive, and, if it is Corian, you'd have oodles of color choices.
Can't help on the hardware, but it looks like Scott has answered that problem. Or, you could track down a local metalworker and swing a little more business toward your community.
Bill, father of a metalworker (can you tell?)
