On cutting drill bits....
Ray Newman
>The pilot hole drill bits for my wood screw counter sinks are in bad shape: dull & one has a flat point from when it was dropped.
The bits are held in place by set screws so depth of the pilot hole is adjustable to the length of the crew.
Problem: the drill bits are only 2 1/4 - 2 3/8" inches long. It is obvious that they were cut from longer bits.
Finding the correct dia. bits for replacements is the easy part. But how do cut them to a shorter length? Aren't drill bits hardened?? Never tried to cut one, but I'm some what adept @ breaking them....
Re: On cutting drill bits....
Tom MacGregor
>An abrasive cut-off wheel on a dremel works. You can also score it with the edge of a grinder wheel & snap it off. You can even grind a small flat spot on the shank for the set screw to make it seat well. Overheating isn't a problem on the end of the bit that doesn't cut.
Bill White
>Grind and snap, then finish the "broken" end on the grinder.
Bill
peter kolb
>Ray,There are shorter twist drill bits called "machine screw drill bits"
which are much shorter than the regular drill bits called jobber length.
How much shorter? About one half the length of the jobber bits. Most of the machine shop supply houses will stock these. Hope this helps. Peter in south central NJ
Dick Coers
>If you buy some of the cheap bits from Harbor Freight you could probably cut them with a hacksaw. LOL They had some really long drill bits, something like 18" long, on sale. I thought that might be a good source of steel for some turning tools. I went in and tried to bend one to get a feel for hardness. It bent so easy my jaw must have dropped.
For some real info on your situation; you may not have enough shank length if you cut all the length off on that end. Might be a good excuse to get a drill doctor. They are great tools and will put a point back on a small bit in about a minute.
