OT Need Computer Help
Ken Oakley-Sunny St. Cloud, Fla.
>I purchased a WD MyBook external drive and hooked it up to my PC. There was no software on CD etc. One tiny sheet of paper said all neccesary software was preinstalled, just plug it in and go. I want a complete backup of everything on my PC on the external including programs and files. I don't think that has happened. Do I need another program to accomplish this or am I not doing something right or both?
Re: OT Need Computer Help
Chuck W
>ken,
which version of myBook did you buy? There seems to be many on the website.
>I just installed a 750GB Seagate Maxtor on my computer. Software came on the unit which installed itself. Its application will let you make backups, but you have to tell it what and if you want periodic automatic backups. Your ALL PROGRAMS list should include the WD applications that you can invoke. A simpler approach may be to get WINDOWS EXPLORER up and drag the C drive contents to the WD.
Clint
John McGaw
>What model number external drive? How does the drive hook up? (USB, eSATA, FireWire? something else?) What operating system on your computer? Can you access the drive at all? If you can access it, are there any files showing on the external drive? If so, what are they called? How are you hooking up the drive? (plugged it in when the computer was turned off or plugged it in while the computer was already running)
>Western Digital 320GB MyBook Home Edition
Re: OT Need Computer Help *LINK*
John McGaw
>In theory the drive was supposed to come formatted and loaded with all software including a backup utility. Or so says the WD website. You can download the full software bundle or just the backup software from the site. See the link below...
WD Backup Software
Mike Fitterling
>Ken, if it is like my Maxtor external drive, when you plug it in a USB port it should show up as an additional drive. Look at the contents of the new drive for something named "setup" or "install". My Maxtor had the software on the drive itself, but it still has to be installed onto your main drive. As mentioned, however, if you don't need any fancy backup scheme like scheduled and automated backups, you can simply drag files you want to back up from your hard drive to the new external drive and not bother installing the software that came with it.
Good luck,
Mike
Jerry Nicholson
>I use my external drive just like you do but I went one step further and reformatted it to NTFS, eliminating all the included software.
Jerry
Da-ding
>Guess we should take this in steps.
First, do any LED's light up when the power switch is turned on? Do you hear a faint whirring inside the external drive? If you hold it does it appear to be spinning with the gyroscope effect you feel with it in your hand?
Assuming that it is working, does your computer reconize the device? Did you hear the typical Windows "Da-Dign" sound when you plugged it into the USB port? Did a window pop up saying it found a new device? Did it ask you what you wanted to do with the device?
If you click on "My Computer" and look at the drives availabile, do you see a new drive? Likely a F: drive or a G: drive? If so, when you click it do you see folders and files?
On most external drives these days, all the setup program files that they used to include on a CD and on the hard drive itself. You used to insert the CD and it would Auto-Run an setup/installation program. Similarly, when they don't send a seperate CD, the AutoRun setup/installtion programs included on the harddrive itself will usually start automatically and load the software.
Some external hard drives, don't come with anysoftware, eitehr on CD, or on the hard drive itself. But if you find files/folders on the hard drive, you probably will find a SETUP program, and clicking it will install some sort of backup utility software. Each hard drive manufacture uses different software. Sometimes it's a scaled down rebranded version fo commerically available software.
As other's have mentioned, there are two approaches to backups.
1 - Simply copy your data files and folders from your C: drive to your G: drive periodically.
2 - Use software that will either manually or automatically backup either selected datafiles, or the whole hard drive.
I use both and there are pro's and con's to either method.
Of course, this all assumes that the external hard drive is working and yuo can see the hard drive and it's contents when you go to "My Computer".
Happy Woodworking!
Ric Taylor
I'm Confused
Ric Taylor
>I'm looking for an external hard drive and easy-to-use software to backup what is on my computer.
The website says the software installs on the computer. It seems to me that if the computer hard drive crashes or needs to be replaced, then the Restore software was lost when the computer failed. Shouldn't that software be on the external hard drive?
What obvious part of the puzzle am I missing?
Ric
Software is installed
>You're right, the backup software is installed FROM the external hard drive onto the comptuer. The software then runs on the computers and copies data and/or the whole thing onto the external hard drive for backup.
If the main hard drive crashes, the recovery procedure differes depending on many factors, but usually means running the software or reinstalling it from the external hard drive in order to retrieve the data from theat external hard drive. Alternatively, it can be retrieved onto another computer.
It all depends if youre' trying to backup just valuable data, or an image of the whole computer (software, settings and data, all together).
There are probably just as many recovery procedures as there are ways to create backups.
Happy Woodworking!
One more thing.....
>"Shouldn't that software be on the external hard drive?"
While most people understand the difference between software programs and data files we create using the software, there is a subtle difference between installed software and software installation files.
Confused? For software to run, it first must be installed on a computer. The software installation (setup.exe) files stored on a CD, or DVD or an external hard drive in this case, will be used to install the software on the computers main hard drive. While there is some software that can run directly off a CD,DVD, flash stick or external hard drive, most software is "installed" onto the computers main hard drive. So to be able to recover, the software must be reinstalled on the computer, before it can restore the rest. SOmethign this invloves reinstall Windows on the computer, sometimes the specialized recovery program can be on and run from the external hard drive while it restores the computer's main hard drive.
Too many different methods and different software to tell you exactly how it works, but that the general idea.
Happy Woodworking!
Re: OT Need Computer Help-Thank You
>Thanks to everyone who responded. I am still totally confused but will read closely all suggestions and comments and see if I can answer my question. I do have some files on the external now but I am not sure about others. Terrible hating something so much that you love so much. I'll have to get my 12 year old granddaughter come over and explain what I need to do.
Make sure you reward her
>If your 12-year old granddaughter comes over to help you, make sure you reward her well. If you need any ideas, check out Jim's thread about what 12 year old girls want for Christmas. Next time you go out to buy an external hard drive you might come back with an iPod ;)
Happy Woodworking!
Re: Make sure you reward her
>She gets rewarded everyday by having "the bestest granpa in the world". Her words, not mine.
