OT - Critters in the overhead?
>I have been hearing scurrying noises at night (the cats are asleep in the bed, so it is not them). It sounds like something is in the space between the 1st and 2nd floors.
I have a 2 story Cape Cod. The front porch roof has maybe a 15-20% slope and the roof has maybe a 40-45% slope. The 2nd floor rooms have knee walls except in the dormer areas. I haven't found any visible holes in the porch ceiling or siding. The only access between the attic area and the porch eaves and knee wall area is between the joists, not that it matters, because I have no access to the attic either (I will be putting in a crawl hole). I have no access to the knee wall area or front porch eaves directly.
I don't want a critter: a) keeping me up at night, b) chewing up my house or wiring and c) expiring up there.
I sort of want to gain access to the suspected traffic zone and put a trap up there. I could put a framed access in the dormer. I could put a framed access in the porch eaves area. I could call an exterminator.
What do ya'll suggest?
Re: OT - Critters in the overhead?
Bill White
>This time of the year (change of season) is the time creatures will go to cover/warmer areas. Rats or squirrels I'll betcha.
Bill
Ken Platt (granby, CT)
>Just a thought - if the areas where you hear the sounds have access down in the basement, you can try putting traps down there. They get around quite a bit. About a month ago I heard those sorts of sounds at the tops of the walls in my home office area. I put traps on the ledge (top of the foundation) below that area in the basement, caught a half dozen mice, no noises since.
Ken
>I had a mouse that skittered back and forth over my computer station in my last house. Mice tend to move indoors when the first cold weather hits. In my case, he took to chewing, scritch, scritch, scritch and no amount of banging would discourage him. Eventually he chewed through his target, a 3/4" hole with romex cables, chewing through the insulation to the hot wires and exploding his little brain all over the side of the joist. I had to cut out sheetrock and run new wiring.
After that, I set little packets of green things that send such small creatures to rodent heaven. I put traps in accessible places. I also went around the outside and sealed up everything I could find bigger than a hairline. Didn't have any more problems.
If you call an exterminator, I suspect they will be gone until next year, then you can call the exterminator again. I like the idea of an access point for placing traps and such.
BTW, if it were a squirrel I think the sound would be louder than a scurry. I had one once in the ceiling above my carport and porch and it was pretty noisy. It had gained access to the attic through a missing rubber plug on a roof vent. I finally caught it with a bucket but that's another story.
Bill Houghton, sorta sunny in Sebastopol, CA
>Mice can fit through holes that seem impossibly small. I've seen access holes you could barely fit your little finger in; apparently their skulls are smaller than they look (in our pre-remodel kitchen, I was dealing with mouse droppings in one kitchen cabinet and found one of those holes; as I considered how to plug it, I was surprised by bright, slightly startled little mousie eyes. A tin can lid was just the right size). I agree that putting out boxes of green pellets (which, it turns out, makes them insatiably thirsty and kind of dries them out) or traps near any possible access point is the way to go.
Another alternative, which I learned from a brilliant guy at our local hardware store, is mothballs. Apparently, mice hate the smell. You may have to put up with your house smelling like you just took it out of storage for the winter for days (see below).
I just finished insulating our crawl space with radiant insulation - basically, very high grade reinforced aluminum foil that's stapled to the bottom of the joists. When I was in progress, the mice had a field day running foot races on top of it, right under our bed mostly, until I put poison in the crawl space.
I also tossed a box and a half of mothballs on top of the foil in the spots that were still open to easy access, which led to our bedroom and associated bath smelling of mothballs for about two weeks. I got to live with a less than amused wife for that period.
Additional comments
>In general, critters make about twice as much noise as their size, it seems. Kind of like one cat we lived with, who weighed less than the other cats but had feet of lead.
My younger son, who lives out of town and has more mouse experience than we do, suggests steel wool mixed with caulk or foam in closing up holes. Apparently, the mice don't like the feel of the steel wool on their teeth, and the caulk/foam holds it in place. Be generous with the steel wool.
I've also closed up holes with tin can lids screwed in with drywall screws. A carpenter's awl (with the metal cap so you can hammer on it) will make a hole in the tin to start the screw, helpful even if you're using a power driver to run the screw in.
Thanks.
