REAL MILK PAINT
Drill Press problems
Ray Carson - Lawrenceville, NJ
>Help please,
I have a floor model type drill press that isn't working the way it should. It's a no name brand. It's painted like a DELTA but literally there are no manufacturers names anywhere. I posted a picture of an example of what mine looks like and the HOMIER website says it's a Speedway brand. Mine was bought at least eight years ago. My brother and I were at a HOMIER tool sale and he bought it for me as a surprise. HOMIER tools sales are the ones where they back up 3 or 4 tractor trailer...trailers, loaded with inexpensive tools and goods made in China. Most of it is junk but you can find decent tools that will fill most of a handyman's needs. Sorry, getting off topic.
Anyway...No matter what position I put the belts in, LOW or HIGH rpm, the motor and pulleys turn but the shaft in the front spins around the steel shaft that turns the chuck. I was going to get the red LINK BELT chain looking stuff but decided to wait until I figure out if the problem is more severe. No sense throwing good money at a larger problem. Once I fix this issue I'll get the LINK BELT stuff. The motor is on a hinge with a spring loaded post to put tension on the motor which in turn puts tension on the belts. You can see this in the picture I posted. The motor is a 3/4 HP and that's all I know. No owner's manual.
Any ideas what's wrong?
Thanks,
Ray
Re: Drill Press problems
Al Stokka - Cambridge, Iowa
>Ray,
I'd first look for a breoken or missing key in the spindle shaft. Can you remove the spindle pulley for a looksee?
Al
>Sounds like what Al suggested, a missing key. Check the bottom of the pulley compartment to see if one is there.
>Hello Ray,
My thoughts also.
George
Keith Newton------WebKitFormBoundaryV6MZb+tiOpocz6
>You are going to have to take it apart to find out for sure. If you can lift the hood, you may be able to tell if the step pulley is turning the upper shaft that it is mounted on or not.
If that part looks good, you may need to remove the quill from the bottom. You may be able to remove the depth limit stop, and just rotate the handles to send it on out, but I think to do that, you pull the handles out so the gears clear.
But before you do that, make sure that the chuck is not just slipping on its taper. With the motor off, just extend the quill down hard onto a block of wood to press it on, then tighten the screw in the top of the chuck. Open the chuck jaws all the way. This screw it normally left hand thread.
Phil Joines in Krum, Tx
>I've had this problem on a Jet at work. There's a nut on the actual spindle shaft that if it comes loose will allow the spindle to slip. Try tightening it up. It's down inside the front pulley so you'll need a socket.
Re: Similar to Phil's
GalenV
>I have an old off the back of a truck Duracraft and it sounds like the Jet. The manual shows a taper fitting the pulley is set on and a nut above the pulley. Just appears to be friction fit, no keys or set screws.
I'd scan the parts data and send if you thought it would help but the sheets are pretty rough.
Bill Houghton, sorta sunny in Sebastopol, CA
>Make sure the pulley is not spinning on the shaft, too. If it was cheaply made, it may have just a setscrew locating it on the shaft. If the setscrew's loose, the pulley will spin.
Our old forced (coaxed, really) air heater had that problem - 18" pulley with no key. I had to tighten the setscrew periodically (gone now, thank goodness - efficiency of about 1%).
del schisler
>check probly a set screw loose Cheep made units don't put a key way in ??? If set screw use lock tight on it Sure would be nice if it at least had a flat side shaft for set screw good luck shouldn't be to hard to fix
Set screw/key
Tom Dunlap
>If the unit has a set screw but no key it's likely that you'll have to go in again. One solution is to file a flat spot on the shaft for the setscrew to seat onto. If the setscrew doesn't leave a 'smile' to tell you where to file wipe a felt tip marker on the shaft, set the screw and then file.
Some setscrews have a flat face on them. Others are faceted like a crown to give more bite. YOu could try a longer setscrew as long as it sets below the surface of the chuck. But...consider that a larger setscrew could inject a bit of off-balance vibration.
I'd be reluctant to Locktite a setscrew the first time it loosened without trying something else first.
Article a/b DPs *LINK*
Tom Dunlap
>FWIW
Drill press tuning
Or
Bill Houghton, overcast Sebastopol, CA again
>if it is a setscrew but no key problem, in addition to filing a flat on the shaft, you can use two short setscrews, with the second one being flat on the end, and use the second one to "lock" the first one. This is not always easy on a pulley, where the set screw has to stay out of the way of the belt.
I know! I know!
Steve Silca
>I had the same problem with a cheap drill press The top pulley is just pressure fit (or maybe taper fit) over the shaft at the top. I would use a large forstner bit and it would seem to stall out the machine, but in fact the shaft was just spinning in that upper pulley.
My solution? Get out a hammer and pound the pulley further onto the shaft. It held well. In my case, the shaft actually protruded a little bit beyond the pulley. So, I drilled a flat bottom hole in a piece of scrap for clearance. Then, flip that piece of scrap over onto the top pulley. The shaft will fit in the recessed hole, and when you pound on the piece of wood, it will jam the pulley onto the shaft better. I keep the piece of scrap on a ledge by the machine and from time to time need to "tune up" the drill press with a couple quick hammer blows.
Re: I know! I know! - You hit the nail Steve.
>First, thanks to everyone for giving me some ideas. Sorry for getting back so late with a response.
The first thing I need to do is to determine (translation - take apart) the front pulley at the shaft and determine if a key or set screw...or nothing exists. I also need to save up enough money to get a better drill press. LOL I can tell the wife that all home improvemnets can't be done without a new drill press. LOL. Christmas is coming and......ahhh, who am I kidding, she'll never buy into that baloney.
Anyway, Steve explained exactly what is happening to my drill press. No mattter what position the belts are in, the shaft for the chuck with a nut in the center of the pulley will spin everytime I load the sucker up with a Forstener Bit. I can actually hold the chuck and watch eveything turn, pulleys, belts and all. Except the chuck and the nut and shaft through the front pulley. Probably a press fit as some have explained. I may need to wack it.
Personally, I think the drill press gremlins are messing with me. :-)
Thanks again WCer's, you rock !!!!
Ray
Re: try tightening the nut first before hammering.
GalenV
>Think you will find it is as Phil and I agree the pulley is on a tapered adapter and the nut should draw it tight. If it has spun enough to wear down the taper you may need a washer under the nut if it has limited threads on the taper adapter. Other option if not worn too bad is use Lock-Tite on the taper shaft. It works well for bearing races that turn and may hold it fine. There is something that bothers me about hammering on a shaft with bearings unless I know I am replacing bearing.
Although it may give you a good reason to buy that new one it sounds like you really want for Christmas.
Chuck in ND
>It may help to take the pulley off if it's that lose and clean both the inside of the pulley surface, and the tapered shaft with some fine steel wool, reinstall, then tighten the nut down tight. There maybe something on that tapered surface preventing it from seating well.
More on Loctite and two other ideas
>If it is just a tapered fit, and you are comfortable with never taking it apart again (at least not without a lot of cursing), you can get a grade of Loctite that's used for holding in bearing races. This may be what Galen was suggesting, but I wanted to emphasize that there are different grades of this product.
You have to clean off your mating surfaces (mineral spirits followed by acetone to remove the mineral spirit residue is good), then put the Loctite on the female surface - the pulley - to minimize dripping down into the guts of the machine, reinstall, and tighten the nut.
Once it sets up, you'll probably be fine.
If that doesn't work, and you're desperate, you may be able to drill and tap a hole down along the mating surface between taper and pulley - basically, making a key from a long setscrew.
Or, of course, you can watch Craigslist and garage sales. Summer before last, we lucked into an old Delta drill press for $25 that's older than me and still better than the modern imported presses. Our son's got it, since I don't have shop space.
Re: One vote from Galen on a new one
>Okay guys and gals, help me out hear. I'll print out the thread and hand it to the LOML as a petition for a new drill press. LOL.
I can use all your votes.
Ray
I love Wood Central - Thanks everyone!
>I'm going to take in all your advice and fill you in as soon as I get it fixed. If I get it fixed. I may have my brother weld the "bajesus" out of it. LOL.
Just kidding...welding would heat up the cheap metal and warp everything. LOL
Thanks a bunch everyone,
Ray
