OT Questions for Bosch SDS Hammer drill owners
>I posted down below about reinforcing a basement wall and the subject of hammer drills came up. Several of you posted about having a Bosch SDS hammer drill. Tool lust has kicked in and I am drooling.
What size do you have? What would you buy if you had to do it over?
What does SDS stand for? Is it better than other impact drills?
Do you have the 3 jaw chuck and is it worth the few extra bucks?
Are there competing tools that are as good or better?
Would you consider a factory reconditioned tool?
How good is bit life? Thirty 3/8" holes 2" deep on one bit possible?
I see some of them (Bosch) are made in China and some In Germany. Would you care?
Anything else I need to know?
Re: OT Questions for Bosch SDS Hammer drill owners
Al Stokka - Cambridge, Iowa
>Barry,
I can only attempt an ansewer to one of your question since I have a Craftsman hammer drill. (I know, but it was an emergency and its not as bad a tool as it sounds.)
SDS, I believe, stands for "slotted drive shaft."
Al
Howard Norman
>I have a DeWalt SDS drill myself. I bought it reconditioned and have no regrets. If I had the choice between manufactured in Germany or China I would pick German manufactured.
I would expect to be able to drill the number of holes you are talking about with one drill bit. Of course it will depend on both the hardness of the concrete and the quality of the bit. Both unknowns.
Earl Kelly
>Barry,
I have the 11255VSR 1" SDS Plus Bosch. I used mine to drill 6 - 3/8" holes 4" dp in less than 10 min. I went out and bought it after trying to use a driver drill and tapcons with unsatisfactory results. When you need holes in concrete a rotary hammer is the way to go.
The only problem is I probably won't need it again for another 3-6 months. But I'll be ready next time I need to mount something solidly to concrete.
Earl
Re: OT Questions for Bosch SDS Hammer drill owners *LINK*
>Barry,
I would absolutely buy again if mine went away.
Mine must be an SDS+ since it can be set to hammer only without rotation. Very useful.
I don't have the 3' jaw chuck but use the bits and chisels that lock into place. The thing hammers so hard it seems like a chuck would have difficulty holding a bit unless just using as a drill. I have other drills for that. I don't know if I would want to use it as a drill because if it jammed, it would twist your arm off.
A reconditioned tool should be as good as a new one, just missing the "new tool" feeling.
I've drilled many, many holes and have yet to wear out a bit. I buy new bits and chisels to get new sizes. I've bought them at Home Depot.
I bought mine at a plumbing supply store. This is the only one I have experience with so I can't comment on any others.
I've drilled lots for myself and others. I will NOT lend a tool like this or any other power tool, but will gladly take it and drill holes for anyone.
Another thing this excels at is chiseling. When cutting a drain channel in concrete under a shower and when cutting a drain box in a concrete driveway, I drilled holes every few inches around the perimeter then used chisels to cut away the concrete. I've had wood which was harder to cut than the concrete. I used a point chisel and one about 1" wide to take out the bulk, and one wider to smooth the edges.
What is SDS?
Hank Knight
>Barry,
I'm one of the Bosch owners that responded to your earlier post. I'll do my best to answwer your questions:
Mine is a 7/8" "Bulldog" SDS rotary hammer. I would buy the same tool.
I think John K. nailed the question about what SDS Stands for. I really didn't know until I looked at his link. I don't know whether it's better than other impact drills. I've used some consumer grade "hammer drills" and I can say without hesitation that it's better than those by a long shot. For one thing, my Bulldog operates in three modes: rotary hammer, rotary only and hammer only. I've used all three. Most hammer drills don't have this capacity. Plus, and most importantly, it drills through concrete faster than any hammer drill I've ever used.
Yes, I bought the 3 jaw chuck and I'v used it. I used to have a monsterous 1/2" Black and Decker corded drill that was heavy adn slow. I sold it when I got the Bosch. I've had a number of occasions to use the drill only feature with the three jaw chuck and I'm glad I have it. One noteable use has been to drill 3/4" dog holes in my workbench with a 3/4" brad point bit. Piece of cake.
I don't know.
Probably. I got a good deal on my Bosch and I have never bought a reconditioned tool. I use my Bulldog fairly often, but nothing like I use my cordless drills and my impact driver. It's one of those specialty tools that when you need it, you need it and nothing else works nearly as well; but you don't need it every day. Consequently, I think this might be one of those cases where a recondidiotned tool might be a good value.
I have drilled literally hundreds of holes in concrete with one 7/16" bit and it's still going strong. I've also drilled many with a 1/4" bit, and I have never worn one out. I'm not saying that the bits last forever, of course they don't. But I used to destroy carbide tipped masonary bits in an ordinary hand drill regularly. That doesn't happen with my Bosch. Also, it probably pays to buy good bits.
I don't know if I can answer this question. I have several Bosch routers and a couple of other Bosch tools in addition to the rotary hammer and I have always gotten good service from them. Bosch used to make power tools in North Carolina, but I have no idea where they were made now. My understanding is that Bosch runs it's own factories around the world and insists on the same standard of quality, regardless where the tools are made. I haven't bought a Bosch tool in a while, so could be wrong about that today.
Not that I can think of, except I that I should disclaim any connection with Bosch power tools except that I'm a happy user. I really like the Bulldog and I don't think you would go wrong if you bought one. I find uses for mine around the house all the time, so I don't consider it an extravagance.
Hank
Barry, Barry, Barry *LINK*
>You mean you don't know what SDS drill I have? Even after I went to the trouble of creating an online catalog? ;) ;)
What size do you have? 1-1/8 inch
What would you buy if you had to do it over? You betcha.
What does SDS stand for? Serious Drill for Sement ;)
Is it better than other impact drills? Infinitely.
Do you have the 3 jaw chuck and is it worth the few extra bucks? No, and I don't think I'd ever had any use for it. My Milwaukee Magnum is for regular drill bits.
Are there competing tools that are as good or better? I really don't like Bosch tools in general, but this is one exception.
Would you consider a factory reconditioned tool? Sure, if money was tight. (like now)
I see some of them (Bosch) are made in China and some In Germany. Would you care? Yes, "formally made in XXX and now made in China" spells "we don't build 'em like we used to"
Mine's made in Germany and was purchased 2-3 years ago. I think the smaller ones are from China and the larger ones from Germany.
Happy Woodworking!
Silly Online Tool Catalog
Ken Garlock, Collin County Texas
>Hello Barry.
As was pointed out elsewhere, a rotary hammer is NOT the same as a hammer drill. The rotary hammer is designed for breaking up and/or drilling in hard things like concrete. It uses an SDS drill.
About 5 years ago, I bought a 1 1/8" Milwaukee rotary hammer. I bought it from a Milwaukee factory service center. It came with a metal carrying case, and a drill chuck thus allowing it to use standard twist drill bits. You can select hammer only, drill only, or drill and hammer.
I have used it for open up a cement block and brick wall. It runs like a Timex -- just kept hammering.
I have several Bosch tools and they are very good, but I really like the Milwaukee hammer drill, it is built like the proverbial brick outhouse.
Happy hunting,
Ken
Milwaukee service center
Milwaukee really makes tough tools
>With what's happened to PorterCable and DeWalt tools, Milwaukee seems to be the toughest tools made today. Probably always have been, just more noticable now. I really like mine.
Happy Woodworking!
