Dantesque chair *LINK*
Re: Dantesque chair *LINK*
Re: Dantesque chair
bobs
>Fred,
The easiest way to do this is to print the drawing you have and take it to Kinkos or another copy place with a large format copier. Measure the length of the leg in the drawing and determine how much to enlarge the drawing to get to the full size length. Then just run the drawing through the copier enlarging it until you get the full size leg printout. You will need to trace over the final copy to make the lines smaller but that isn't a big deal.
Bob
Re: Dantesque chair
Henry (Raleigh NC)
>It is doable without a large format copier, and I have done this several times.
I'd print the original image a large as you can on whatever printer is available - use legal size 14" paper if you can and print in landscape orientation so that this diagram is printed along the long side of the paper.
- Copy/enlarge until the image is the full size of a piece of paper.
- Divide the image into thirds (needing 3 pieces to get to a 30" template) and enlarge those thirds until each is 10" long.
- Enlarge each piece exactly the same amount (arbitrary example 200% and then 56%) and then reassemble the three pieces to a full size template. The grid lines help here.
Of course a large format copier is easier, but Kinko's is more expensive and less convenient than my cheapo desktop printer/scanner/copier/fax.
Henry
Re: Dantesque chair
Fred Davis
>Bob , thanks for the response ,
I have tried the easy stuff already and the response I got from CopyCat over the phone was "we can't do that unless you have the exact scale to calibrate the large format copier"
Had a conversation with a Architect who had time on his hands and he said " I charge a hundred bucks a hour and probably could do it in half a day" .
I immediately went and looked in the mirror for a sign I was completely unhinged and decided he probably read one of my remarks about Architects in general.
Since this chair was made around 1525 without all of our superior drafting aids , I will get this done ,even if I have to take it to the high school.
FredD
Got it
>Send me your address and I'll mail it out tomorrow.
