Ice
Ice
Ice
Ronald from NW Ohio
>What is the best way to remove ice from my treated wood deck? I heard not to use salt on it. So what is the way to remove it?
Re: Ice
Re: Ice
mark nowicki
>The weather. Check your local forecast.
Regards
Mark
Re: Ice
Re: Ice
Ken Oakley-Sunny St. Cloud, Fla.
>cover it with a black tarp on a sunny day. Of course it will probably freeze again when the temperature drops.
Re: Ice
Jim DeLaney, Austintown, Ohio
Re: Ice
>I push the snow off mine with a stiff bristled push broom, then lightly sprinkle the deck with sand. I find the fine playground sand from HD works very well. Hose it off in the Spring, and it leaves no marks or residue.
Regards,
Jim D.
Re: Ice
Dale Lenz
Re: Ice *LINK*
Dale Lenz
>Check out the last bullet, near the bottom of the page of the link below.
Salting your wood
Re: Ice
Re: Ice
Pete LaBelle
>Chemicals will do damage to the wood, finish, and/or fasteners. Besides, they will track into the house.
A) Shovel off as much as you can and let the sun do it's work (decks are typically pretty dark and draw the solar energy.
B) For a temporary fix (like for a party) throw a piece of indoor/outdoor carpet on it.
Re: Ice
Re: Ice
Ronald from NW Ohio
>Thank you all and i will go today and see if i can find that sodium chloride salt. Thanks Dale will give it a shot.
Re: Ice
Re: Ice
>You shouldn't have to look to far. Sodium Chloride is plain old rock salt. It's available pretty much everywhere.
