OT: Convert VHS Tape to CD/DVD
Tom Rex in TX
>Our family has about 100 of these tapes that the grandchildren watch. They take up a bunch of space. What's the cheapest way for me to convert them to CD or DVD?
Re: OT: Convert VHS Tape to CD/DVD
Glenn Madsen
>I bought a DVD recorder tape recoeder thingy from Sony at Costco last year. Maybe $200. Works well, when we use it.
Mine was to take DVR recordings off of the TiVo...
William H. Falberg
>If you can stream them into your computer with MovieMaker, you can edit and "save to" DVD.
Me too............
Frank Mutchler
>William, I have a PC interface on my HD TV. Can I use that? If so, there is no option in MovieMaker for 'TV' (I'm running Vista).
Under 'Import', would I choose 'Digital Video Camera'?
Under 'Publish To: would I choose 'DVD'?
Ken Oakley-Sunny St. Cloud, Fla.
>I saw a device at Radio Shack about a year ago that did what you want. Best I remember it was a little under $100. Also CNET.com had or has reviews on devices also with sources, prices, etc.
Re: Me too............
William H. Falberg
>This is way out of my area but I'll run through my process. I have to re-install the driver for my Sony video cam every time I want to upload video; so do whatever you have to to introduce your "new hardware" to the computer. That done; you open MovieMaker and on the task pane select "import video". You get a drop down showing whatever video devices your computer thinks it has connected at the time. If you see your DVD player listed, that's great! you're half way there! (That's always the hard part for me) Click 'Start Download' on the computer and 'play' on your DVD player. My camera has a "Video Streaming" setting that has to be activated; I don't know about players. Then you wait, and wait, and wait. When you reach the end click "Stop" and wait some more. It's pretty slow, even on my computer, but eventually you'll get a collection of clips which you have to "combine" by selecting them all, right-clicking, and hitting "combine clips" Then you can edit in the preview window. When you're all done editing and adding silly sub-titles you look down toward the bottom of the "Task Pane" and where it says "Save Movie As:" you click on DVD (or CD if there's only ten minutes or something) I save mine as "Best For Editing On My Computer" first, because that's where you edit; but when it's ready to burn you select the media you want to record on. You can also select the size of the file desired and it will compress it down to e-mail dimensions (It gets pretty well pixellated though.) Hope that helps.
Tom
>The easiest way, bar none, is to buy a dvd-recorder. Connect your vcr, press play and record and wait. Dvd recorders are pretty cheap now too, especially those with analog tuners. The only problem with this method is if the tapes are commercial tapes. Many/most of them will carry a copy-protection signal (Macrovision). Most, if not all, dvd-recorders won't work with those. Neither will most, if not all, digital camcorders in pass-through mode. You can still get it done on a computer, with the right hardware. Hauppauge makes a few tv-tuner/capture cards that ignore the macrovision signal (most 150 and 250 models do that). You can connect your vcr to the card/usb device, press play and record and it'll leave a file for you ready to burn to dvd with the right software. You can also try a time base corrector device, connected to a dvd recorder. That's fairly expensive though.
Well, here's what I did........
>I gave away all the VHS tapes and with the good karma I received back (that and some hard earned cash) I re-bought them as DVDs. But in all fairness, there wasn't a hundred that I had to re-buy, only the favorites.
Oh, you wanted the CHEAPEST method. Sorry ;)
Happy Woodworking!
Frank Mutchler
>Boy, a lot of great input. I appreciate the help....Tom, you got what you need?
Steven Antonucci
DVD-R/DVR
Steve Antonucci
>If you own a DVD-r, you can burn some of them to a DVD. Nice thing is that you can probably burn more than one to a DVD, so you shouldn't need as many.
If you find some that are copy protected, throw them out.
As an alternative, you could also burn them to a DVR. No disks, and you just pick them from a menu. Way, way easier to manage.
Only issue is that you need to sit through all 100 tapes to do it...
Steve
Re: VHS Tape to DVD - Brookstone  *LINK*
Ray Carson - Lawrenceville, NJ
Ion� VCR 2 PC VHS-Ripping Recorder
>I agree with Tom - a stand-alone DVD recorder is the quickest. Sure, you can digitize the video signals several ways and load them into the computer, but then you have to let the computer do the encoding and write the DVD. With the recorder, it's one step and you are done - the encoding is done in real time. (The only time involved is the time it takes to play the video once.) A reason NOT to do it this way is if the source material is too long for real-time recording on one DVD and needs special compression on encoding.
In fact, when creating DVDs that needed some authoring, say, menus, indexing points, autorepeat, etc, regardless of the video source, I would often record the signal directly to a DVD recorder (these usually give you a pathetic little menu for an interface) then use ripping software to pull off the video file to use as input to my DVD authoring program, create an image file, then burn as many copies as I need.
