Have a question? Ask Woody!
Shop Fox fence "slider pads" . . .
steve mackay
>OK, TS up & running but burning a bit. Back to the book. OH ! HEY, you adjust the thing ! No more pinching between blade and fence and no more burning. Last night . . . burning. Hmmmmmmmmmmmmmmmmmm. Look down and one of the plastic / silicone (?) pads that make the fence slide smoooooooooooth is on the floor. Looks like they are just pressed in sooooooooooooooooo . . . a dab of the Ol Super Glue. So far so good but I just know its going to come off again, get sucked up into the vac and be gone for good. Any other suggestions to secure them ? I can't be the only one. And I don't want to imagine the nightmare of trying to talk Griz out of replacements.
Re: Shop Fox fence "slider pads" . . .
Mike Bauer
>I've had my "Alumi-Classic" fence on my Grizzly TS for about 15 months now and have only had this problem once - about a month ago. Don't think it is going to be a major headache as you think. The pad on the other end that supports the fence has already worn out, though. Could have been a little thicker or provided with replacements in packaging.
Dick Coers
>I think some good quality double back tape would be the answer. I wouldn't use the thick foam type that is used for auto trim, just some good cloth carpet tape should do the job.
Probably right, . . .
steve mackay
>We all want stuff to stay new forever I guess ! Since you've got one . . . what would you think of "shiming" the length of the slot the fence rides in with thin,long plastic "block" to eliminate the side to side "slop" when the fence isn't locked down ?
Bill White
>Can't imagine that Griz would not readily supply replacements. I have the Aluma Classic on my G0444Z with the same set up. Not needing replacement yet, but.....
Bill
Shimming the groove...
Mike Bauer
>...sounds like a good fix for the slop - never actually thought of it. I'm sure it would help in the few cases where I wasn't using the fence's "tape measure" to set up my cut, but rather just trying to line the blade up with the cut line. My only concern would be that the groove would fill up with sawdust - which it typically does - and this might cause binding between the fence and the shim, if any were to get between the two.
