Drive-thru Shelter (OT?)
Hal Langerud
>I'm looking for plans for a drive-thru shelter for my golf cart. Could be wooden or pipe. Covered with canvas or something similar. I've found ready-made units, but the shipping costs are horrendous. So might as well build one myself.
The finished shelter would be around seven foot high at the peak and probably six feet wide.
Thanks.
Hal (on the York River in VA)
Re: Drive-thru Shelter (OT?)
EMT and tarp
>I've made some for golf carts, etc by bending inexpensive EMT to make a frame and covering with a tarp.
That's basically all those ready made one are.
Happy Woodworking!
>I've seen cloth-covered shelters for sale around here in a variety of places. I bought one at a local Pep Boys automobile parts store a couple of years ago. Powder-coated steel pipe frame, fittings instead of bent tubing, heavy duty fabric roof. A couple of hundred dollars.
Dave Bair, Eaton Rapids, MI
>They are very noisy in the wind and will abrade through, where the fabric touches the frame, in year or so.
Glenn Madsen
>We bought some to use as seasonal dressing shelters for the swimming pool program. If the wind blows much, we have a problem. Last year, the wind blew much.
If it's your property, you can build something pretty cheaply from wood that will last for decades. Not portable, though.
wooden leg
>For my friends that live in very little wind, they buy those 10' x 10' pop ups. They fasten them to the ground using stakes or rebar. They then buy cheap blue tarps and using plastic wire ties fasten the tarps to the frame. That way they can use them in the summer for shade or camping etc. Around here the pop ups go for about $90. Dave
PVC Quonset hut *LINK*
John E in SC
>Boy scouts in our area often use these for shelters when camping - not ideal for long-term use, but great if you're just looking for a short-term covering.
PVC Quonset hut
Hal Langerud
>Yes, I think wood is the way to go.
Now I just need some plans, not being much of a carpenter.
Thanks to all who responded.
Hal (On the York River in VA)
No plans needed...
John E in SC
>if you want something pretty simple. I built a 12'x12' cover over my dog kennel awhile back for about $200 worth of material - it's 4x4 posts, with the front 2 about 2'taller than the back, with 2x6's connecting the 4 corner posts, a ledger strip on each of the side 2x6's, with 2x4's running across (I think on 24" centers), and a few corner braces on the posts. Roof is tin. The 2' slope has been enough for rain runoff, but we hardly ever get snow here - if you're in snow country, you might need more of a slope to prevent loading.
John
The quickest way I know to put up a building is the way farmers have been doing it for ages, with pole barn techniques. There are lots of good books and probably some internet info. Basically, you dig some holes, stand some PT or cedar posts or old telephone poles in the ground (4x4 pt would probably be fine for what you need), tie them together horizontally with 2x lumber, add a roof (simple flat lean-to roof is simplest), and fasten up some siding. A little gravel on the ground and you are done. Make sure the ground slopes away to keep a stream from running through the middle when it rains.
Hal Langerud
>Thanks, John. Sounds like something I can handle (with younger help).
I'll draw something up and see what I can come up with along those lines.
some pole construction info *LINK*
>The link below shows a book I have which is very helpful with design and construction techniques. It shows a variety of outbuildings and how to proceed.
As for age, look what this grandmother put up - a 24x50' pole barn for under $3000:
http://www.motherearthnews.com/Do-It-Yourself/1995-02-01/Animal-Shelter.aspx
Google reveals lots of info, especially if you as for 'how to build a pole barn' which will filter out some of the companies trying to sell you a kit or build one for you. For example, here's a great page showing a little drive-through shed with a gambrel-style roof using pole construction:
http://www.extremehowto.com/xh/article.asp?article_id=60282
good book
