Re: OT: Computer screen problems
Pat Evans
>Thanks John. In response to your questions:
"Do you have controls like a stand-alone monitor for bumping the position of the picture on the screen?" No
"What happens to the screen when you change the display resolution? Is it SET to the correct parameters?" The problem remains when I change resolution. Also, yes it is set to the correct parameters. I'm running Windows 2000 and it tells me if I choose a non optimal resolution.
"I don't know about laptop screens, but even if connected by a multi-pin connector it might help to unplug and replug to reseat the connectors. This fixed one of my LCD stand-alone monitors.
Note that laptops (and other such electronic things!) are often very difficult to get apart since they are usually assembled with hidden snap locks. Be prepared to mutilate the plastic. Also, internal components are fragile." The screen is connected via ribbon cable and multi-pin connector. I had to replace a broken hinge, subsequent to the display problem, and was hoping the disconnection/reconnection might help. It didn't. That the position of the screen (ie whether it was fully or partially open) affected the problem made me believe it was mechanical, such as a broken wire or loose connection. That may in fact be the case, and disassembling it made it worse. You're right about hidden snap locks, but I managed to get it apart and back together without destroying it.
"But look on the bright side - new laptop computers have gotten so cheap they are almost giving them away in cereal boxes. :)" I'm retired and living on my investments. With the stock market and my IRA in the shape they're in, the only way I'll get a new computer is if someone is giving it away.
Thanks for your help. Hope someone has other suggestions.
