O.T Heater ducting
O.T Heater ducting
O.T Heater ducting
Craig in Silverdale
>This past summer I expanded my cabin and the current heater can't heat it anymore. I don't know much about sheet metal work, nor do I have the tools to do the job. I purchased a furnace on E-bay from a wrecked 5th wheel. Was wondering if I could use 4" ABS piping in lieu of metal venting? I will need to insulate the duct work in either case and will build a box around it with OSB of plywood to keep the neighborhood chipmunks from stealing my fiber glass. Thanks in advance.
Re: O.T Heater ducting
GalenV
>Craig
It does not take much to work galvanized duct work since you can get rectagular and round shaped duct as well as about any type fitting you need. Tin snip, drill, jig saw(optional), screw driver, sheet metal screws, GOOD GLOVES.
The furnace you have I assume is down draft for connectin to a plenum in the floor.
Is the ductwork just in a crawl space under the cabin and why you want to insulate and protect from critters?
They do make flexible insulated duct and a version for outdoor application for mobile homes for one use. You can probably google and fine to look at.
You may need to use both metal and the flexible as I imagine you will not be lucky enough to have all outlets run between two floor joist. You may be dealing with running 90 degree to floor joist which will mean dropping everything below that level.
The 4" ABS is probalby going to be harder to work with fewer fitting and besides you need a larger plenum to start the run.
Not a fun job IF a crawl space below the cabin.
Galen
