Elm, is there a going rate????
Jesper, Denmark
>Is there a goimg price for 8/4 Elm?
Yes it is European, but the problem is the same over here - trees almost gone. I have some access to some fropm felled park trees and wonder what it should be worth?
Jesper, Denmark
Re: Elm, is there a going rate????
Dale Lenz
>In Eastern Oklahoma on the Western edge of the hardwood forest, very little competion as compare to farer east, elm would be priced on the stump, stumpage price, somewhere between 120~200 dollar/1000 bd.ft on the Doyle log rule. Hope this helps. Dale
that is blocking
Tom Sontag - St. Louis
>That price suggests it only gets to market as blocking or pallet or tie material. I believe it.
Re: that is blocking, maybe
Dale Lenz
>120/M is pallet, 200 is entering the sawlog grading market above pallet grade, believe it! Trouble is as suggested elm does not carry a hugh market. Elm warps easily when drying, machining is questionable. All of this information is on A. elm. Slippery elm is better behaved, I've been told.
Hey Dale, Being a few hundred east of you,
Keith Newton------WebKitFormBoundaryV6MZb+tiOpocz6
>I think most of the Slippery Elms around here generally carry a bit of scar tissue, due to this being where Granny Clampitt left from before she Jed. Jethro, and Ellie moved out to Beverly Hills back in the 60"s. Most of her lot still like to make a tonic from the bark. ha.
I am sure there are plenty of you on this forum that can remember that she made a strong tonic for whatever ails you, from Slippery Elm bark. I wish I had her receipt.
The way I treat my liver, I probably ought to join them, by going out and harvest a little from a slippery one next to my shop, to make a batch of tea just for good precautionary measure. he he
