Surge Suppressor Question
Tom MacGregor
>Could you get better protection by plugging two surge suppressors together in series?
Re: Surge Suppressor Question
Bill Howatt
>I'm going to say probably not. The typical ones have devices in them that look like a high resistance to normal voltages but they will breakdown and draw current from the over voltage spike to reduce its voltage when the voltage is too high.
A properly working single one should clamp the voltage such that the second one would have nothing to do. You might feel a bit safer though should the first one fail the second one would take over.
On a more subtle note the extra capacitance of the second set of devices and the inductance in the supply wire might add a small amount of filtering but I wouldn't really rely on this doing much.
I use them but I don't believe that they will really protect your equipment if you get a good hit in spite of the claims they make. The best place for suppression is in your electrical panel where it can be tied to a good ground with the shortest length of wire.
Bill
