Bolting Unisaw to pallet
Mitch from Canada
>Hi all,
I just bought an 8 yr old Unisaw and am looking to get it home now. I was going to bolt it to a pallet and use a forklift to get it on the trailer...does anyone know what size of bolt holes are in the base of a Unisaw?
Also, transporting it standing upright on the trailer, can I safely use tie down straps across the top of the saw table to help hold things in place? Or will this warp the table?
Thanks for any help.
Mitch
Re: Bolting Unisaw to pallet
Yes, yes @ yes!
Art Silva
OOOOPS! No to bolts, yes to straps.
Art Silva
Rick L
Re: Way too much thought process...
Rick L
>Just flip it upside down and strap it in. DONE! Former Independent Delta Tech and 25 years repairning machines!
Mitch from Canada
>Flipping over might work. Lowers the centre of gravity etc... It still has the side tables and 52 inch fence attached...do i have to remove those to flip it?
My biggest concern is to make sure it doesn't damage the table top.
Thanks.
Mitch
Forrest Addy
>I agree with Rick. Flip it upside down on a piece of clean plywood. I;ve taken my cabinet saw saw to jobsite and loaed/unloaded it single handed.
Here's how I did it. Let the tailgate down. Wax up a 4 x 4 sheet of OSB. Lay the OSB flush with the edge of the tailgate wax side down so it can slide between the wheel wells. Lay a piece of carpet about the size of the saw table on the OSB for padding.
Remove all appurtanences above the table. Remove the blade. Remove the insert and toss it aal in the box with the opther loose stuff. You dont need to remove the spar unless it interferes with handle the saw. DON'T lift the saw by it. DON'T lift the saw by the wings.
Bring the saw to the tailgage about 8" (adjustable number; you want to hook the table edge over the tailgate) away. Tip the saw so the table contacts the OSB. Pick up the bottom edge of the cabinet. The weight will force the truck down against the springs a bit. Lift up the bottom edge of the cabinet and raise it through an arc to invert the saw onto the OSB table down.
There will be a moment when the center of gravitly passes over the table edge where the saw wants to take charge and flop onto the bed with a hell of a whump. Here's where a helper in the truck bed comes in handy. He resists the flop and lets the saw down gently. When working single handed I used a cardboard filc box to cushion the flop. I prelovated it so it would be half way under the edge so the saw when it went over center, the saw collapsed the box absorbing the energy.
When the saw is safely uplide down, push the waxed plywood into the truck bed and close the tailgate. Lash the saw to the truck so it doesn't slide with road accelleratios in any direction.
When unloading work the plan in reverse.
That's the basics. As with any heavy lift walk through each step before the actual move anticipating and measuring so you know in advance everything that can happen. Safe moves are no accident. That's not just clever words. A good moving plan has verything worked out so there are no surprizes, busted handwheels, pinched fingers, dents, scratches, or fatal injuries.
Got it home
Mitch from Canada
>Used a pallet from a Saw Stop. I went with the "keep it upright" school of thought. Just nailed wood blocks on the outside of the base through the pallet to keep saw from moving. I also removed the side table and fence.
Picked it up with Forklift (had one guy also standing on pallet just to steady the saw). Plopped it on the trailer. Two straps across the top...30 minutes later, it's in my garage and it's AWESOME!!!!
Ok...I've been looking to get ANY table saw for more than a year so you'll have to excuse my excitement.
Thanks for all the suggestions.
Mitch
