Mostly OT, Drilling holes in concrete
>I am trying to reinforce a basement wall by building a heavy duty stud wall inside it. I need to anchor the bottom plate to the slab. I have an old good quality hammer drill, but it is not working well. I am drilling holes for the TapCon type screws. (3/16" holes)
My question is would renting a significantly more powerful drill make this job substantially easier? If so, what would you use? (I could drill larger holes (3/8"?) and just epoxy bolts into the holes.)
Re: Mostly OT, Drilling holes in concrete
>I typically drill my holes with an old 1/2" Sears hammerdrill. I usually don't have any problems with concrete or cinderblock. I usually use a new bit or I sharpen my old bits. With concrete, a bit will usually last through one hole before I need to sharpen it.
My $0.02.
Dick Coers
>It's tough to beat high quality tools and bits when you are drilling concrete. I have a really old Milwaukee hammer drill that walks through concrete about like drilling wood. Speaking of wood, are you drilling through the wood and concrete at the same time? I tried that a couple of times when I was trying to save time. That never works well. The carbide bit hates wood and really drills that slowly. If you are really looking for strength in that joint, consider using construction adhesive.
Ralph Lipeles
>Almost all of the load on a wall is top to bottom, not lateral. So, when I build a wall I use 2" cement nails. They dig into the comcrete about 1/2" and that is enough to prevent the wall from going anyplace.
Infinitely easier
>A good SDS drill is so much easier than a hammer drill in concrete. Used to take 10 minutes to drill a 3/16" x 2" hole and one day I spent $25 and rented a Bosch Bulldog SDS and drilled a 1" x 10" hole in about 2 minutes. I was amazed at the difference and bought one a few years later.
Like others have said, there are alternatives to drilling for your application, but if you need to drill then a SDS is your best/faster method. Not the most economical for only a few holes, mind you. Just the easiest/faster.
Happy Woodworking!
Mark Nowicki
>Hello Barry:
Are you sure you are using a carbide tipped drill bit and is the drill set on "hammer"?
Another possibility, if you are drilling the same distance from the wall, is that you hitting the rebar.
I have both a corded Makita and a cordless Milwaukee and I have no problem drilling for 3/8" Tapcons.
Regards
Mark
>This is not the typical situation. I actually want little or no load from the top down. The problem is that the block wall is bulging inward. There is a long horizontal crack in the wall about chest high. It is in effect a hinge. What I am doing is trying to anchor a 2 X 6 wall inside the existing block wall to provide some lateral support. The theory is that if you anchor the bottom so that it can not move inward and then anchor the studs to the joists at the top so they can not move inward, the strength of the wall will be added to the strength of the block wall and give it back the strength it lost when it cracked. So I want the top and bottom anchored so securely that the studs would break before the bottom plate moved.
The typical home owner response tot he crack in the wall is to install tile-columns inside the wall to take the load in case the wall fails. When the posts are screwed into place they take the load off the top of the block wall. Its the pressure on top the blocks that give them much of their resistance to over turning or bulging. If you take the weight off, the wall bulges inward, knocking down the teleposts. So that process makes things worse. The wall collapses.
Another aspect to the problem is that the basement wall is wet. That means the studs are treated and the treatment process is very corrosive to steel. I will be using fasteners rated for treated wood.
no contest
>Barry,
Use the big one.
I personally think the "hammer drills" sold to consumers are nearly worthless except perhaps for putting anchors in cinderblock. Many years ago I bought a heavy duty Bosch professional hammer drill and have used it to drill and chisel through some pretty hard concrete. I've cut drain channels in 4" concrete and drilled hundreds of holes up to 1" diameter.
There is NO comparison to the hammer drill vibrator setting on a small electric drill, regardless of the bit you use. Been there and done that.
These tools are only a couple of hundred dollars and should last a lifetime of casual use. If I try hard enough I can usually find some excuse to buy a good tool.
As for your wall, rather than adding wooden bandaids to a wet bulging basement wall, if this is a retaining wall with dirt behind it's too bad you can't fix it right from the outside - excavate, add a drain, seal.
Jim DeLaney, Austintown, Ohio
>You're not gonna like hearing this, but all you're really doing is adding a (relatively poor) bandaid. You're not really fixing anything, just hiding it.
The wall is bulging in and cracking due to the soil pushing on the outer side.
The only real fix is to dig down on the outside to remove the pressure, re-set/rebuild the wall, waterproof it, and add a method for draining off the water that's really the cause of the problem.
For what you're trying, the Tapcons will be temporary at best. They're not designed for the side load you'll be applying to them, and under side stress, will shear off. If you must use a bandaid system like this, you'll need to use some heavy concrete anchors a lag bolt the (hopefully pressure treated) sill plate down using 3/8" lags. Even then, I doubt it'll hold for very long.
That said, good luck!
Jim D.
Re: Mostly OT, Drilling holes in concrete *LINK*
GalenV
>Barry
Agree with others that wood reinforcement is a bad fix.
I help my step-dad set 6" steel channels in a cement pocket into the floor and then used hydraulic jack at the top secured between two floor joist to preload the channel. I guess the wall never caved in but over time it did start bowing the channel even more than our preload. Wood will be no match against the wet earth pressure.
Not learning they bought another home with wall problems and had an anchor wall system put in per the link. Again wall never caved in but you spend your life tightening the rods and probably just pulling anchor plate closer to poor wall and eventually no support.
Never solved the wet conditions and finally the home walls started to crack from the foundation bowing to the point the sill plate drops or twist.
Just two examples of temporary partial fix.
Anchored Wall System
Re: Infinitely easier
Hank Knight
>I couldn't agree more with Mark's recommendation of an SDS rotary hammer. My basement shop has poured, reinforced concrete walls. I talked to a Bosch factory rep about buying a hammer drill for various concrete drilling jobs in the shop and he talked me into buying the smallest Bosch 7/8" "Bulldog" SDS rotary hammer for about $185. He explained that the rotary hammer technology is different and much more robust than an ordinary hammer drill. He was right, the Bulldog makes drilling into hard, reinforced concrete a piece of cake. I must have burned up a hundred carbide masonary bits in regular drills and hammer drills over the years and cursed every one before I got the SDS rotary hammer. I've never ruined a bit in the rotary hammer and I've used it a lot. I don't have any comments about your basement repair, but if it involves drilling holed in concrete, get an SDS rotary hammer.
YUP ! Pay the Man ! . . .
steve mackay
>you'll be done in an hour !
Re: Wet wall & bracing
Ray Carson - Lawrenceville, NJ
>Hello Barry,
I read through this thread and was listening to your problem. You say you have a "wet" basement wall that has a horizontal crack. What your dealing with is "hydrostatic pressure." You may have already figured this out. I commend you on attempt to rectify the problem. However...
The key in most of these cases is to eliminate or remove the water from or away from the wall. Secondly, a wooden stud wall will help but in time the lumber will get wet and get flexible. This is not a long term solution in my opinion.
I've stated before that my 16 yrs. plus as a structural draftsman does not an Engineer make....and my current quest of becoming a New Jersey Licensed building inspector also does not make me a structural genius. I've seen first hand and I've been on way too many inspections with our Engineers here at the office to know that this should be handled differently. Also with my inspections for my inspectors license this is or could be a problem in the future for you in a liability standpoint should you sell your house. In New Jersey a homeowner is allowed to make certain repairs but NONE that are structural. You might want to investigate your local town codes just for the record.
I'm not trying to frighten or scare you and you do what you need to do. I will state again that I'm NOT a licensed Engineer. I want to help is all.
I would be interested in hearing more about your wall, the length, the height, thickness, soil conditions around your property, drainage, the design and layout of your stud wall bracing, etc.
I realize your presently constructing this wall and turning back may not be an option. Still, I am very interested in your problem and helping you out.
Sincerely,
Ray
p.s. I would have used powder-actuated-fasteners to anchor my "sill" plate to the concrete slab. :-)
Re: John's comment....
>about the band-aid and drain pipe....
right on the money John. :-) Two thumbs up!
Re: One last word....
>Barry,
I have one last word and I'm going to shut. Sorry. Attached is a VERY typical detail we give contractors who ring our bell asking for a fix for the exact problem you have. In addition to digging down and getting the water away from the wall we recommned the following detail be constructed to shore up the wall prior to the drainage work. In the 60 years+ experience of the owners of our firm this has never failed us in terms of providing a permanent solution. Again, the key is getting the water away.....
This may look like overkill but ...IT WORKS!!
Kneale Brownson. Skiing now in Colorado
>You need to excavate outside that wall and solve your water problem. You can reinforce the wall outside then too. Your treated interior wall may not rot, but it'll mold.
>The wall is about forty feet long and seven feet tall. I will have to look and see what the thickness of the wall is. I am sure it is hollow CMU's. The water problem is relatively recent. My father had the house built on the farm when I was about 15 and I am 59 now, so it is close to forty five years old. Dad passed away and my step mother moved to town and rented the house for about the last ten years. The tenants never cleaned the gutters. The water made the soil soggy at the foundation and the wall cracked in a long horizontal crack. There is now noticeable settlement between the shrubbery and the wall. Water off the roof ponds in the area and has found a way into the basement. Not much, but a few quarts.
There is no money to make the repair. As a Home Inspector I am aware of all the repairs that have been suggested and am aware that an exterior fix would be superior to what I am doing, but business is slow and the funds are not available. My plan is to put the band aid on it and see what happens. I will reinforce the wall to be sure it does not bulge further and then fill around the foundation to create a positive slope. The gutters need some attention also. They have sagged and of course the overflow right over the front stoop. On the next decent day we have I will clean them out and realign them to drain properly. They drain into drain tiles and I will try to figure out where they drain to. (I lived in this house from the time I was fifteen to Eighteen, when I left for college and have not been back for any length of time, just the occasional visit.)
At this time, I am afraid to try to excavate the wall for fear of knocking it in. The bracing on the inside should make it safe enough to dig it up later. What I am looking for is to improve the gutters and the surface drainage and dry out the soil around the foundation.
I may dig a trench in the yard parallel to the wall and drive some heavily galvanized rods out through the wall to the trench and pour concrete around the ends of the rods to create a "dead man".
Thanks everyone and....
>As a former builder and a Home Inspector I am aware that what I am doing is not the best possible solution, but the cost fits the budget and will put it in a holding pattern until times are better.
I appreciate all the suggestions. I am thinking through them and may apply some or all as money permits.
Powder Actuated fasteners Question?
>Ray, I was considering Powder actuated fasteners, but I don't know if they are corrosion resistant. I was concerned that between the corrosive nature of the treated wood and the fact that the location is wet or damp, they would fail over time. I guess I will google them.
I also want to check out some heavily galvanized steel rods to use as tie backs to a dead man in the yard.
Andy Lincoln,in Dearborn,MI
>Barry,
If you require an SDS style drill on a budget,check out your local Harbor Freight,their drill can be had for about the rental cost and I believe a 2 yr warranty is like $7.If I had to use one day in and day out,might not buy a HF but for occasional use,....
Andy
R. Gryder
>Another possible anchor system is to use expandable bolts. they are available in 3/8 or 1/2 " and would give you the lateral strength you would need to hold the plate in place. Lowes has them and I suppose any good building supply. R.
Re: Deadman.
GalenV
>I have to believe your attempt to pour in place deadmen would be better than the galvanized plate they put in my mom's. The first adjustment was just taking up for the loose fill in the hole they made to put the deadman plates. I think some of the rods actually ended up with no more adjustment as rods were only threaded so far.
The rods they used must have been 1 1/2" as it took my larges box end wrench to fit the nut. The thread had antisieze compound so they did not rust and free to turn.
If you thought you could line up use a post hole augar and fill as a deadman.
Know what you mean about sometimes just making do.
My mom did finally sell the last home and sold "as is" and still did well even though the new owners could clearly see the "fix".
Galen
Fred Davis
>Barry ,
the problem you describe is a not uncommon occurrence around here in Dickinson county , Kansas and the fix for years has been the same whether it was a basement repair company or a farmer, they all do the same and it works.
You are seem to be familiar with it to the point of running steel rods through the wall to a trench outside . We use a trencher here to cut a slit trench about ten feet from the wall and parallel to it and drop in two foot long steel plates about a 1/2' or so thick , (depends on the farmers iron pile for size) slit a trench back to the wall every four feet or so and drop in a heavy steel rod threaded on both ends , run though the wall and nutted on the trench end outside.
Plate the inside same as the outside and draw up slack until your plumb and straight.
If you have used a trencher , you should have no problem with loose fill as Galen said. This approach seems to work with less work and expense then any temporary shoring done on the inside.
Though you may be familiar with techniques, you never know until you have done it how much work your looking at.
It doesn't cost anything to get a basement repair guy to check it out for you , you don't need a Hydraulic engineer, Hydrologist, etc. , it's all grunt work.
BTW if your block is hollow and not grouted , when you get it straight, see if you can pour grout into the block cavities.
Well worth the effort.
FredD
Re: One last word....sounds like a plan Barry
>It sounds like you know what your getting into and realize the problem is the water. When funds are low, a band aid is all that some can afford. I get it. Really, I'm in the same boat. No pun intended.
I was just trying to help. Let me know if I can be of more assistance.
Sincerely,
Ray
