HELP - Wood ID
HELP - Wood ID
HELP - Wood ID
David Yoho
>I'm looking for your help and best guess as to what kind of wood a friend of mine has. He sent me a small sample so I sanded the face and end grain surfaces on my belt/disk sander in hopes to give a better view. The pictures have not been altered for color - just cropped and resized.
All my friend knows about the origin of these heavy planks he has is that they might have been used in the construction of an old train tressel maybe in Africa.
The wood is sort of a redish brown dry and a darker red color when wet. I have included three pictures of the small sample I was sent. I hope with the sketchy details and pictures that someone will know what it is.
Thanks,
David
Face grain
face grain - dry
End grain
End grain
Wet
Wet
Re: HELP - Wood ID
Sapele?
Re: HELP - Wood ID
Steven Antonucci
Might be Teak
steve antonucci
>I think Clay Foster (turning) also had some...
Re: HELP - Wood ID
Re: Might be Teak
Tony - Memphis
>If it is teak, you can make a cut and see the oxidation ring around the edges. Also, try cutting it. If it dulls everything in your shop, then it is teak! I'm building a garden bench out of the stuff now. Can't wait to get done with it. It really has killed every cutting edge in my shop. My planer sounds like it is cutting with dull butter knives. Soon as I am done, I'll have a sharpening/knife replacement party.
The wet sample does look like the teak I am using. The center of every piece I cut is a yellowy color. You can see the layer of oxidation very clearly. It seems to take a week or two for the color to change. Looks great with teak oil applied. Your sample is nice looking. Like the color.
Tony
Re: HELP - Wood ID
Re: HELP - Wood ID
Michael Bush
>David,
If it's teak, cutting it will tell the tale, as others have said.
Does it have yellow stuff (like sulfur) in the grain? In the picture it looks like it might, but it's hard to tell from the picture.
If it does, it could be what in Brazil they call Pao Ferro. (I think every culture has at least one wood they call "iron wood," and sometimes more than one.) it collects sulfur in the grain. Here again, cutting it would tell you, because there will be a lot more of it where it hasn't been rubbed or washed out.
Re: HELP - Wood ID
Re: HELP - Wood ID
David Yoho
>Yes, Michael, though it might not show up in the pictures well, there is yellow stuff in what looks like open pores in the surface of the wood. I hit it with blasts of compressed air after sanding but the stuff didn't blow away.
Thanks,
David
Re: HELP - Wood ID
Re: HELP - Wood ID
Michael Bush
>Ah. Pao Ferro, then.
It finishes magnificently, but dulls your tools as badly as teak.
It's from the Amazon, though, not Africa.
Re: HELP - Wood ID
Could be anything
>Your samples don't ring any bells for me, but if it is from an undeveloped region of the world, it might not be anything you've ever heard of. I'm always amazed by the number and variety of oddball species that grow in the Third World, and only a fraction of them make it into the export trade. Every country, whether in South America or Africa or Indonesia or wherever seems to have plenty of these Lesser Known Species, and many of them are extremely dense and hard.
I'd say the only way to get a good fix on this one is to send it off to the FPL for a determination.
Re: HELP - Wood ID
Re: Could be anything
Tony - Memphis
>I work for a large transportation company. A buddy of mine works in the avionics area where we get very large airplane parts delivered on large pallets. He brought me two big timbers of some sort of "tropical" wood. I have no idea what it is. I'm a little hesitant to mess with it since I don't know what it is. I've read horror stories... He said that somebody in his work area has used it for some projects, but wasn't sure if it was the same wood. Anyway, what is FPL and where can I find out more? I have these two huge pieces in my garage and I'd like to use them or get rid of them.
I can't wait to get done with this teak garden bench. I've never had so many splinters and my planer sounds like it is cutting with dull butter knives. Jointer too. Even my trusty old #7 that I use for getting lumber ready for the jointer/planer is groaning. Beautiful wood though. It will be worth the effort. I tried some Watco Teak Oil on a piece and it looks really nice. Its a shame that it will mostly be covered with cushions! Oh well.
Thanks,
Tony
Re: HELP - Wood ID
Gary Evans Tallassee, TN
>FPL=Forest Products Lab. You can send them a sample and they will identify it.
Gary
