OT Water Heater Insulation
Sawman
>Just installed aan electric WH to replace my LP one. What is your thought about an insulation wrap?
Re: OT Water Heater Insulation
>If the water heater is in unconditioned space, insulation will help. Better to install a timer to accommodate just the times when hot water is needed.
Clint
Forrest Addy
>Heck yes insulate it. The water heater is thermally inefficient.
Save about $10 per month and put a ready made jectet on it. Save even more by placing plastic wrapped 6" batts all around and over top, taping them in position. Make it pretty bu building an octagon enclosure around it if you have room.
Speaking of, how many have homes have you seen with "mechanical rooms" where the W/H, water softener, furnace etc are spread out some distance from the wall like furniture in a hotel lobby? Wastes a ton of space. I'm all for service accessibility but I've seen water heaters and air handlers set uot like art exhibits. If you wanted to store a box of christmas decorations you'd almost have to put them on the carpenter's work bench.
>Insulate it as well as you can. It would have been good to set it on a piece of foam with a piece of plywood on top of the foam to keep the heat from conducting out the bottom. (much more important on a slab than a wooden floor.) Also insulate both pipes about fifteen feet out from the heater if you can. New heaters usually have some sort of device in the inlet/outlets to prevent the water thermo-syphoning inside the pipes and it may not be as important to insulate the lines, but it couldn't hurt to do a couple of feet.
Insulating the pipes is an interesting topic. In winter the heat that escapes inside the the conditioned space is beneficial and not lost, but might not be as CHEAP as Te heat produced by your heating system. In summer that heat is not only wasted, but is a double whammy in that you pay to air condition it back out.
In winter your cold water pipes take heat out of the house as the water warms up. It is possible that the cold water pipes cost you more in lost energy than the hot pipes. Might pay to insulate all of them when you build a new house or have easy access.
GalenV
>Read the instructuions to new water heater put in this year. It says not to install an exterior insulation blanket. What does your manual say? It says it will effect the thermostat that controls the elements. I would think it would monitor inside temp and not be effected, but what it says. Installer put on pipe insulation that came with the water heater. One on the cold water inlet and one on the hot water outlet.
Says it will help prevent radiant heat loss and MAYBE cut down on cycle of heating elements. Told me if I insulated more of the hot line it would not do much other than might provide hot water faster but depends on usage. If gone all day water will be cold anyway on first opening of hot water. Upstairs bath always a long time to get hot water with low flow conservation type faucet anyway!
The new water heater does have a thicker jacket than my old, so newer unit are SUPPOSE to be more efficient.
Check your water heater manual especially if you want to stay in warranty.
Ralph Turney
>I have a good friend who's a plumber and when I moved into this place he came over and installed a new 50 gallon water heater for me. I asked him to buy the best quality unit from his supplier that was available and he gave it to me at his cost, so it wasn't too bad. When I asked him about the wrap since my unit is outside, (although being in Southern California it really isn't an issue) he told me not to bother, but said that if I had bought one from Home Depot or some other cheap source that it might help. The same brand that you buy from a plumbing supply house and the one you get from HD are a world apart in quality. You get what you pay for (most of the time).
On the other hand, I just got back from a trip to New Jersey and Washington DC and man o man it gets cold!!! So living in Socal I may have to bow out of this thread... :-)
Ralph
>The assertion that a to-the-trade wholesale supplier sells better stuff than the big box is myth. Where do you think el-cheapo builder gets his appliances? And, for apples to apples, the big box is gonna be less expensive.
Size matters. The smaller the unit to meet the need, the less expensive to buy and operate.
Clint
Ralph Turney
>Sorry Clint, it's not a myth, but you're welcome to believe what you want.
Fred Davis
>Ralph,
It hasn't been all that long since I worked in the building trades in Ca (11 years) and all of the WH shipped at that time came with fitted insulating blankets.
Also the Earthquake code standards adopted after the NorthRidge one that dropped the VA hospital, require strapping the WH to the walls.
Water heater replacement and or installation require a Mechanical permit and inspection all over the state. A plumber knows this.
FredD
Re: CA state regulations question
GalenV
>Fred
Interested in other state regulations.
In California could the general public not buy and do a home install on the QT or were units only sold to plumbers and contractors?
Strap a water heater! Like will the wall be standing it is strapped to?
We had to come up with anchorage for large steel filters and water storage tanks. Like they think current code will really save them from the big one comming! Calculations I did are all theory anyway. But by the book!
Iowa:
Plumber installed my water heater and the city inspector came late. He stood in the kitchen and signed the inspection tag. Went downstair and in one motion stuck on the sticker and turned to leave.
NO inspection!
California any better I wonder?
Galen.
Tony - Memphis
>Our plumbing contracto shopped at Home Depot. I didn't relaize this until I just happened to see the HD sticker on the heater one day. Not sure of the brand, but 10 years and counting.....Hope I get to count a few more years! Down here, all heaters are in the attics. Well, most anyway. I put a bnlanket on ours. Not sure how much that small bit of insulation will help, but it was cheap. Ours is gas so I made sure to keep it away from the flame box. Also installed a cutoff with leak sensor. Good insurance. Also made sure all the pipes were good and insulated.
Tony - who was thankful for that nice hot shower this morning....as were my co-workers!
Fred Davis
>Galen,
Yes , anybody can buy a Water Heater and try to install it.
There are "know it alls and I can do it cheaper" types everywhere and they get into serious trouble all of the time.
Case in point: In the Bay Area in the late seventies and early eighties, a Black guy got a 100,000 dollar SBA loan and used it to send a flyer to every household in that area, hundreds of thousands of households.
This flyer touted a 50.00 off of a WH installation by his company, which consisted of young dropouts , not a plumber in the entire company.
My gullible Aunt had his guys do a installation for her and when I saw it , I called the building department because....
there was no T@P valve on the WH, the heater was in the Garage on the floor , rather then on a stand elevating the pilot light 18 inces off of the floor as code required, no permit , overflow was dumped into a laundry tray , so if the heater blew and your standing at the sink you would be scalded and so on. Every possibile requirement for safety was ignored.
After I and other contractors ran across some of these jobs and reported them , the various building departments refused to issue permits to the guy and basicaly shut him down.
As you said about the inspector signing off in the kitchen, this is pretty common when the inspector knows the plumber who did the work and knows the guy is concientious about his work.
One last word about DIY types and the home they and their families live in and expect to be safe in , as they should be able to.
Three areas in home building and maintence that should be left to the various building trades and contractors for obvious safety reason , are Electrical installions, Plumbing installtions, expecially Gas fired units and HVAC work , all requireing mechanical permits and inspections.
Even your Structural and Mechanical licenses do not qualify you to do these, unless you can do them to code, which always invites a closer look at everything when the inspector knows he is dealing with a home owner installation.
Check with Barry ,I would venture to say he sees booby traps every week in his house inspections .
FredD
Fred Davis
>Tony,
A little know fact about Water Heaters which I think I have mentioned before is about the age of them and the two different garantees you can get. Most of the WH heaters are sold with a 5 year garantee, you can get a ten year garantee with the same unit , only difference is the length of the garantee and the higher fee for the unit , all of the rest is the same.
So your looking at a unit that is older now then a manufactuers garantee would indemify for , so you can bet the efficiently has declined , by as much as 50 percent.
FredD
