>I am in the throes of designing this year's Christmas ornament and I thought about a Candy Cane. Could I take dowell rod and steam or boil it soft enough to make that tight of a bend? The most common species of wood available in dowell rod is oak, cherry, walnut, and some sort of unidentified white wood. Which would work best if at all?
>I don't have a lot of experience steam bending, but I am pretty sure you would have about a 99% failure rate, plus or minus a couple of percent. Makers of Windsor chairs rive the pieces for the bows so they can bend them with fair reliability and that radius is MUCH larger than what you are thinking of.
>It would not easily be possible to bend kiln dried dowel rod. I've bent many a chair hoop and I've used green or air-dried wood for almost all of them. Kiln drying sets the lignin in the wood such that the fibers won't slide enough during the bending procedure. I've made glue laminations out of kiln dried and have had numerous failures with steam bending.
I have bent small round steamed green wood pieces (white oak) into candy cane shapes. I've also used concentrated ammonia ("borrowed" from the lab") to make green wood flexible enough to almost tie knots.
Do you have access to relatively straight grained green wood? I'd prefer shaping it with drawknife and spokeshave, but if you don't have those, you can saw it into 1" square billets. Then you can use a router table to shape it into rounds (be very careful!). You can try steam bending those.
>Do you have any dogwood? I was cleaning up the other day and while trying to break some dogwood slices for the woodstove they would bend double with a small radius before breaking. This was even half dried. I imagine you could tie them into knots if steamed.
For a candycane ornament, I might try turning a dowel from green dogwood or bradford pear on the lathe. (Thin spindles are easier to turn if chucked tightly on one end instead of between centers.)
Or hammer some pieces through a home-made dowel plate like Roy Underhill would. (Drill a hole in a steel plate, ream slightly so the hole is wider at the bottom.) They dowels can look better than those shown in the link below. Woodcraft sells a nice dowel plate made by Lie-Nielsen.
>Kinda depends on how many you want to make, but I think that bandsawing out the cane shape, then 4 passes on the router table with a roundover bit would make some really nice candy canes. This technique would also lend itself to bloodwood/maple laminations for the true striped effect.
