>A friend gave me an old pub table he got from the trash behind a pub in England years ago. It's in rough shape. It has words scratched into the wood, etc... so I decided to sand it down and refinish it. It will be the first piece I've ever tried to refinish. I have two questions;
1) What kind of wood is it? Some parts look like oak, and others mahogany. I don't know what chestnut looks like, but a friend thought maybe it was chestnut...
2) What can I do about the different colorations of the wood? Is there a specific product or technique that can even it out a bit? I was thinking about maybe a darker base with a lighter top as the top wood is very pretty and would look nice in a lighter shade.
>This wood appears to be Spanish cedar, which is similar in appearance to mahogany but lighter in weight. To even out the color, I suggest a thinned coat of a dye stain. If you want the whole table to be darker, use a full-strength dye stain or NGR stain prior to finishing.
>Pete, Ellis may be right about the Spanish cedar - he's seen more wood than I - but to my eye it looks like mahogany. Nevertheless, there is a way of evening the light and dark areas of a wood like this.
I'll leave the "why" to those more versed in finishing but here a method I know works. It works better when sprayed but wiping will work too. The first step is to apply a yellow dye - I prefer the water-based powders from W.D. Lockwood. Any yellow will work.
After that dries, apply the color of dye you want for a final color and proceed when dry with your choice of topcoat. You will end up a with a very uniform look to the finish. I've seen this work on cherry and mahogany and it probably works with most others too.
>Thank you both. The wood is very heavy, as heavy as any oak or hickory I've used before. Could it still be Spanish Cedar? Also, it has small holes where some critters have been munching on it in the past.
Another question... I'm considering leaving it with the rough worn edges instead of trimming them down... Opinions?
>I think it is probably a somewhat course, lower grade mahogany, since it's heavy. I've had a lot of it that was used to make shipping containers for Amazon crafts being imported to this country. David has seen that and maybe even worked some of it years ago. (I also still have a little of the 1400 bd/ft of purpleheart I once had that was used for the same purpose.)
Spanish cedar does look a lot like mahogany, but it is light in weight and has a distinctive smell, like a cigar box, which is what it is often used for.
