A55 Smoothing Plane
shoulder plane
shoulder plane
shoulder plane
Frank on Chesnut Hill
>Gentlemen,
Just completed installing 400sq ft of Brazilian Cherry flooring. There were several instances where the width varied by up to 1/16 on an inch.
It came to mind that if I had a shoulder plane I could have quickly improved the fit up even with an installed board.
Has any one used a shoulder plane for this purpose?
Thank You, Frank on Chestnut Hill
Re: shoulder plane
Absolutely
>Shoulder planes are excellent for this kind of work, but depending on how the tongues and grooves were milled, it could be difficult. If the rabbet under the tongue is deeper than the one on top, you can tune up the gap by simply shoulder-planing the top rabbet. You can do that in place while the board is on the floor and before you nail it in. If there is not enough additional clearance under the tongue, it will interfere with any corrective measures you take on the top rabbet and you will have to either take the board out and shoulder-plane both sides or relieve the underside of the groove an the next board. In both cases, you need enough extra depth in the groove to allow a certain amount of tweaking. Most custom molded flooring takes all these variables into account, allowing you a small amount of tweaking range, say up to 1/16" or 3/32" with nothing more than a bit of shoulder-planing. Of course, manufactured flooring rarely has such width discrepancies.
Ellis Walentine, Host
Re: shoulder plane
did this just yesterday
Bruce, a MN Galoot
>with a custom milled threshold I made for a guy. It had to bridge the varying height differences between two existing floors, and between my 78 and the LV shoulder plane, it was a snap.
bruce
Re: shoulder plane
Thank You FFG
Frank in Forest Hill
Re: shoulder plane
If the rabbet on the bottom of the tongue
Bill Houghton, foggy so far in Sebastopol, CA
>interfered, couldn't the floor installer use the shoulder or some other rabbet plane to trim the lower "tongue" on the grooved side of the board?
Wish I could draw it, but our scanner is not yet tied to our new computer (GOT to fix that!)
