First of all, you might be able to try a program called SpinRite from www.grc.com. I am not sure if it will work given that the drive is clicking it sounds like a mechanical problem, but if it is not mechanical, this program might help you recover your data. Nice program to have around. Not something you use every day, but when you need it, you NEED it.
The best bit of advice I can give you is to go out and get a large external hard drive and Acronis True Image Home 2009. Use Acronis to backup to the external drive. If you need even more protection, check out Amazon S3 as an online storage option. It is dirt cheap and reliable from all I can tell so far.
Acronis actually images the drive. I have restored crashed Windows XP Pro systems using Acronis backups in less than 20 minutes. If you do a daily incremental backup, you can always restore to the system state you had the day before. If you get and can determine when you were infected, you can RESTORE to the day before the infection and be back up and going in no time. You can get a 15 day trial to try it out. There are some other neat features also.
As usual, not monetarily invovled, just a very very happy customer.
I know your pain,I too have lost things when computers unexpectedly go bad.The advice that Rob gave is very good.I noticed in the local paper Target has a 750GB external drive for $89 for the next two days of shopping madness.I intend to pick one up to replace a failed 320gb ext hard drive.See the link below to download the Google Toolbar.
>If a harddrive is clicking non-stop, that means it cannot to its initial test; might not even be able to read the rest if its firmware from the platters. Could mean that one head is dead. That could happen if it was overheating for long time
There are data recovery services that would put the platters into new chassis with new head assembly and get the data out. Prepare for >$1000 price tag.
>external drive on my computer a month ago. That plus lots and lots of CD backups makes me happy. I have 10 years of genealogical research and records on my PC, plus tons of photos I would hate to lose.
Years ago we recovered several unreadable disks with a simple technique, but that process depends on to factors: 1, the problem being in the electronics, and 2, having a spare drive of the identical type. Occasionally the circuit board attached to the drive has a component failure. In that case, it is sometimes possible to substitute a circuit board from an identical drive and access the data again.
The data recovery services are very expensive. You have to have some pretty valuable data to make it worth while.
As for backing up favorites, in Firefox you can open "Organize Bookmarks", then export to an HTML file. This puts them all in one file that can easily be saved elsewhere (and easily opened and browsed if needed). Internet Explorer puts this export feature is on the File menu.
As for backing up in general, I don't back up the OS, just changes I've made. One easy way is to connect an external large capacity HD to the machine and copy everything that you can't reinstall easily. I like the firewire disks - I have four connected to these machines. Purchased boxed software packages can usually be reinstalled easily.
To make reinstalling downloaded software easier, I make a directory called "installs" and put all the required files for each program in a separate folder along with a text file of any special unlock codes along with vendor, date of purchase, and telephone numbers. Back up the 'installs' directory by simply copying it to an external drive.
>Recovery software will work if you have a corrupted boot record or other file problem but it's useless if you have a physical problem with the drive - and a clicking sound is indicative of a physical problem. Download the appropriate diagnostic software for the drive from the manufacturer's website and run it to determine if the disk is damaged. If the software says the drive is kaput then you can still try a couple of things:
- mount the drive in a different orientation (vertical if it was originally horizontal, or turn it upside down or on its side)
- put the drive in a Ziploc bag and stick it in the freezer for a few hours (or a day).
The underlying assumption in both methods is that internal parts are worn and that altering the physical conditions may allow the drive to spin long enough to extract the needed data.
Then, there's always the "rap it on the side with the handle of a screwdriver method". Hit it hard enough to free up the heads but not so hard as to send the heads skittering across the platters. Try this method last since it might damage a drive that could be recovered via the other methods.
>If your drive clicks at power up and never comes ready, you most likely have a bad head, or a bad preamp (which is on the armature that holds the heads).
In either event, the drive has to be opened and inspected (by a pro--don't open it yourself) to see if there is any surface damage. If the head actually scratched the media, the cost goes up dramatically (most D/R firms will just tell you the drive is unrecoverable as the rates can hit the multiple thousands of dollars, the kinds of prices only large institutions are going to be willing to pay--and there is still no guarantee of recoverability).
If the media looks good, a pro will swap your head stack with a stack from an identical or compatible drive. Tedious work at best, nearly impossible on some drives like Western Digital units where the stack axis is locked by pressure from the top cover.
The most important thing is to get an accurate diagnosis. Clicking is often a head/preamp problem, not always.
If the data is important, don't risk giving it to anyone else that is going to try connecting it to a standard PC. DO NOT run SpinRite, DON'T freeze the drive. Don't keep powering-up the drive in hope that it will work "one last time."
Likely the data on the bad drive can never be recovered. Its a good time to institute a good backup schedule using an external drive and backup software. Try Syncback because its a nice program and there is a free version.
>I can usually recover the drives that others can't. And if the unlikely even that I can't (it did happened once about 6 years ago) there's a cleanlab that I use when it's beyond my capabilities.
>Hi Barry, my hard drive was clicking the other week and refused to work. I took it to the city to get it checked but, which enjoys a warmer climate than where we live up in the mountains, only to find the shop was shut. I returned home and gave it another try and wola, it worked like it used to. All I can think is that the warmer less humid air did the trick. I have since made a copy of all it's contents onto another drive, just in case.
>I get the impression that your loss of data is but an inconvenience rather than an outright disaster so going to extreme measures is not really warranted. It sometimes doesn't hurt to get forced into cleaning things up - my favorite links probably have a lot of dead ones now and others I haven't looked at in years.
I also like another poster use SyncBack for data files and it is great although I sprung for the purchased version since I wanted versioning. I also, like another poster, use True Image to make images of my OS/applications partition. I don't keep any important data files on my C drive so it can get blown away at anytime.
The OS and applications can always be reinstalled it is your personally created data files that need the special care. I also suggest that if one external drive is good for backups, two is much better, do a backup to each drive in sequence so if one goes south you still have the other disk even if it might be one backup behind.
Whatever backup program(s) you select be sure you can do a test restoration. To many people find out their backups either won't restore or they weren't capturing everything they thought they were.
