Re: lap joints question
Curly Smith
>Were you thinking of this:
"You need to adjust the height of the blade (or bit) so it cuts exactly half way through the thickness of your stock. But I don�t use a rule to set the blade height.
Instead, I start by setting the blade slightly below the half-way point. Then using a test piece (one that is the same thickness as my workpieces), I gradually sneak up on the height, see Fig. 1. To do this, just make a cut on the end of the test piece. Then flip the piece over and make a second cut on the same end. You should have a thin �sliver� left over. Now just raise the blade a hair and repeat the process, removing a little more from each side of the sliver until it�s completely removed. When it is, the blade will be set at half the thickness of the workpiece."
from this Woodsmith PDF: Cut Perfect Half Laps
