hardwood dowels
hardwood dowels
hardwood dowels
Paul Blackwell
>Have you noticed that the quality of wood dowels has gone downhill dramatically lately? I make lots of wood toys, and need dowels that are round and somewhat near nominal size. The junk available in most stores is terrible. It's not birch or maple, but some soft brownish wood, and the size is as much as .050 undersize. To make things worse, they're so out of round that they're just about unusable. I started searching on the net, and ordered some from an outfit called Woodworks Ltd. located in Texas. They arrived today, and the quality is outstanding. They are within .002 of nominal size, and perfectly round. The website is www.craftparts.com. They are available in birch, maple or oak. They've been around for more than 30 years, and worth a look if you need wood parts.
Re: hardwood dowels
Thanks for the tip, Paul
Re: hardwood dowels
Lauan?
Alex Grigoriev
>Soft brownish wood - lauan? (AKA philippine mahogany)
Re: hardwood dowels
Re: hardwood dowels
Ray Binnicker
>I, too, just recently ordered from these folks and I will be a repeat customer !! I needed 40 oak shaker pegs (3" long). Everything local was over a buck each. I found these folks from Texas and they listed bags of 25 for a little over 7 bucks a bag. Two bags later and they are quality pegs.
And they are prompt shipping.
Ray Binnicker
Re: hardwood dowels
Re: hardwood dowels
Fred Davis
>Ray,
consider ordering a dowel die from LV, I did in three sizes and I wish they had been available years ago.
The beauty of the die is that it is adjustable for the stated size , so you can get a press fit in your drilled hole.
FredD
Re: hardwood dowels
Re: hardwood dowels
Ray Binnicker
>Thanks Fred,
I didn't think of the die. I did consider the dowel plate. But, at a little over 7.00 for a bag of 25 I didn't think I could go wrong.
Thanks again,
Ray
Re: hardwood dowels
Re: hardwood dowels
steve mackay
>Always wondered about those !
Re: hardwood dowels
Re: hardwood dowels
Fred Davis
>They are well worth their price which is reasonable and if you buy one or more of them , be sure you get the optional long shank 9/16ths socket to turn the square stock with you drill motor.
FredD
