oil finish on walnut
Erick Singleman
>I am planning to make a slant top desk of walnut, and would like to use an oil and wax finish on most of the piece (except for the writing surface). My experience with oil and wax is only with cherry which does not need grain filling.
Can you use oil and wax in combination with a grain filler? If so what would the process be?
Re: oil finish on walnut
Louie Lovas
Louie Lovas
>Walnut is one of my favorite woods to work with. Specifically Oregon black walnut, I find it to have the richest look when finished. If you've not already bought your lumber, here's a place I've purchased from:
http://gobywalnut.com/
I assume you mean an oil/wax mix in your question. I'm quite sure you can apply that over a pore filler. They are compatible. If you're interested in alternatives to oil/wax however. I've done a lot of experimenting with walnut and found a really good way to enhance that grain. I've described it on my website on one of the walnut tables I've built.
http://www.flinthillfurniture.com/portfolio.html
Goto this site, scroll down the thumbnail images and click on the round walnut coffee table. I provide a detailed description of the finish technique I used.
Best of luck,
Louie
on Henthorn
>I always found that oil muddies the color and figure in walnut. Just my 2 cents.
Jim Dillon
>Erick,
The Autumn 2008 issue of Woodworking Magazine has a nice article on finishing walnut. After experimenting, the author (Glen D. Huey) chose tinted shellac. Reddish-brown TransTint aniline dye was added directly to amber shellac, then sprayed, brushed, or wiped on depending on the size of the piece. The author discusses adjusting the sheen to taste, and topcoating with other finishes, provided a coat of non-wax containing shellac (Zinsser's Sealcoat) is between the tinted shellac coat and the topcoat. Might be worth trying. I have only limited experience using orange shellac followed by a varnish/oil blend. Seemed fine, but next time, I think I will experiment with the above recipe.
Jim
