Sanding,,,,,, I hate sanding,, but,,,,,,,,,,,,
Keith Newton------WebKitFormBoundaryV6MZb+tiOpocz6
>I remember making that remark back in the late seventies to a couple of shop mates, only to have them look at each other, then back at me. If I recall correctly, they accused me of lying, along with the remark that after anyone else would be finished, I would still sand for another full day.
While that may have been true relative to their perspective, it didn't change my perspective. I just finished sanding about 90 drawers, which I think of as brain-numbing work, but when I try to find someone who can do the fine work, I am never satisfied.
There are just simple little things that I try to teach helpers, that seem so natural to me, that just seem to make no sense to the normal helper. For instance, the fine art of using a random orbit sander, and just how to apply the pressure to the pad as you move around the work. This is not to even mention near corners.
I am sure that we all understand that there is a bearing on a off-center arbor on the motor, which spins, but the pad has a bearing allowing it to spin freely relative to the resistance or friction to the sanding disk.
As long as the pressure is flat to the disk, the pattern may seem random orbital, and at times will seem to run in random directions, or wander, pulling the user in unexpected ways.
However, If a little tilt of pressure is applied to the tool, this may be eliminated unless the pad shaft is bent, which make is worse if the tool has been dropped. But the point I would like to make, is that tilting the pressure a bit changes the pattern of the sanding action to a certain direction.
If you think of the old Train steam engine, where there was a piston pushing a rod that was connected to a bearing on the outer edge of the drive wheel. It is easy to see how this would turn the wheel. When you tilt, you are applying resistance on one plane of the orbit, so now the wheel is providing the power, but now the drag of the abrasive is the opposite of the drive cylinder which is back and forth, relative to the tilt angle.
If you understand that there are certain directions which cut easier or harder relative to the grain of the wood. This can speed the sanding process, and or improve the finished product. To be more specific, wood cuts easier across the grain, but finishes better when it is sanded along the grain.
So when sanding something as I just finished on about 90 veneered drawers. If I can see some scratch from the previous sanding, I may tilt the pressure across the grain for faster cut, but then back to down the grain for the finish.
I just wondered if others of you do this, and or if this was a common practice? I don't recall ever reading it back when I took the magazines. Or am I just crazy?
I know there is a lot out there that I have missed. Do you agree, or disagree with my impression. I think it falls under the category of "for each action in one direction there is an opposite and equal force, only ~ opposite to that.
Re: Sanding,,,,,, I hate sanding,, but,,,,,,,,,,,,
steve mackay
>Although I sand by hand, yes, I'll admit, I'm a sander also. Just another affliction I suffer from. Shifting light highlights a scratch in the wrong direction and off we go. It normaly takes the next project screaming out loud before I say "enough" and move on.
>Good Morning Keith,
The older I get, the more I sand, and the less I like it. And, the less I like it, the more convinced that there is no gain without some pain. So, I sand. Maybe its wanting to take more responsibility for the job at hand which compells more attention to detail. I'd hate to think of someone looking at my work and remarking "too bad he didn't take a little more time in surface preparation".
George
Dave Bair, Eaton Rapids, MI
>I know what you mean. I just finished installing the last of my kitchen cupboards. It's taken almost 2 years; some because I lack the room to build and store more than one or two units at a time (and actually did 5 seperate installs) and some because of the need to do as fine a job as possible on the finishing.
I was satisfied, even if no one else could tell the level of effort used. However, I overheard a gratifying conversation that went something like: " They look nice, but you should feel them, they're like glass." Now, that's nice to hear and made the extra effort worth it.
Alex Grigoriev
>I don't know why you hold to it that much. In my experience, a few passes with a card scraper is enough to get the piece as smooth as glass, even if it was all rippled by a bad thickness planer. The downside is that you'll have to roughen it a bit with a sanding block, if you want to apply stain. Another thing is you cant scrape soft wood well.
Fred Davis
>Is there a written test after reading , multiple choice, true or false ?
Just wondering here
FredD
Yes, there will be a pop quiz.
>Do you always hold even pressure on the pad, or apply more to one side for a reason?
Elaborate. ha,
I guess that a couple of days of just sanding left me with too much time to think while my hands were on auto.
