Have a question? Ask Woody!
Upcoming project questions
mdclor
>Good evening to all,
I will build a bed headboard (SHMBO doesn't want a complete frame) based on Robert Lang's Shop Drawings for Craftsman Furniture, page 98. This calls for M&T joinery of pieces up to 7.5 inches wide. I looked at the Shrinkulator and, if I did this correctly, it looks like the movement for QSWO will only be in the range of 0.03 to 0.06 inches. The RH in my shop is currently about 37% and I estimate the RH in the house may get to as low as 20% in the winter. We are located outside Albuquerque, NM. Now for my questions: 1. Am I understanding the calculations correctly? 2. For this movement, should I make 2 M&T's for each of the wide joints? 3. Is there any advice anyone would care to share in the making of this piece?
TIA,
Merle
Re: Upcoming project questions
Bob Lang
>I think you'll be OK. I usually leave a bit of room in the width of mortises-mostly to be able to take them apart while fitting, but also to provide some room if some swelling takes place. The shoulders should cover up any shrinkage.
Bob Lang
>I'm currently making a headboard similar to your description. It will have five separate vertical panels M&T'd into horizontal top and bottom rails. The hard maple tenons are from 6 to 10 inches in width. Our ambient humidity ranges from around 40% to 90% throughout the year, so I plan to accomodate any seasonal movement by limiting the glue area to the center 2-3 inches of each panel and running a couple bamboo dowel pins into the center area of the tenon from the back of the rail. I'm sure there won't be any problem.
Clint
mdclor
>Bob & Clint, thanks for your replies. I feel much better now about moving forward with this.
Merle
