colored glue
Galen
>Is it possible to add some latex stain to Titebond glue to make a colored glue joint without losing strangth?
colored glue
Galen
Re: colored glue
>You can dilute Titebond somewhat. I haven't used latex stain, but I have used Transtint dye. I usually put a little bit of glue in a yogurt cup and add a couple of drops. If you have the latex stain, it doesn't really cost much to experiment.
yes with caution
Bill Tindall, E.TN
>A friend that ran a furniture factory used to tint the glue for certain applications.
However, these adhesives (as well as latex paint) are composed of tiny balls of polymer dispersed in water. The balls don't crash out of solution because they are held apart by a charge on their surface. Adding charged stuff, for example salts, to the glue can interact with the charged polymer balls and can make them crash out of solution into a gelatinous blob.
Some dyes are charged and some concentration of the charged dye could cause the balls to crash. But, It is likely the amount you will add will not be a problem. To a first approximation what ever you can do to latex paint you can do to the glue.
Re: colored glue
Fred Davis
>Seems to me that a food dye or color would have fewer problems with glue formula , it would certainly be cheaper to use.
FRedD
Food dyes not that color fast...
>some of them are "fugitive" and many will fade over time and exposure to light.
Re: Food dyes not that color fast...
Fred Davis
>That is a good description of most dyes
FredD
OT: Another Galen in Iowa??? :-)
GalenV
Re: colored glue
Steve Schoene
>I work so hard to fit the joint so well that I get an invisible glue line, that I don't quite understand wanting or needing to dye the glue.
By the way, on another forum, someone recently asked Titebond about gluing joints which had been stained with a watersoluble aniline dye and apparently was told that it wasn't a good idea--that anything that penetrated into the cells of the wood could weaken the bond and indicated that the water in the glue might dissolve the dye, also a problem. This sure didn't conform with my understanding, but unless the info was reported incorrectly, appears to be the Titebond position. Don't know if it came from a real technical person or a PR person just answering questions in the most conservative way possible.
