Thanks Darrell Peart!
Jim Dillon
>The moment I saw this end table in Darrell Peart�s book Greene & Greene: Design Elements for the Workshop, I wanted to build it. Thanks to the nice picture in Darrell�s book, I was able to come up with something that fit my space needs. The small dimensions (17Lx12Wx18H) were dictated by the narrow space available between a comfortable reading chair and the fireplace.
The wood is entirely African mahogany except for a cherry plywood drawer bottom, and the traditional ebony plugs etc.. Unlike Darrell�s table, I did not add a bottom shelf as I wanted to see the floor tile beneath the table, and perhaps more importantly, I was afraid I would just clutter up the shelf with junk.
Except for twelve stub tenons in the side stiles, the piece is joined with 40+ Domino loose tenons. Even the breadboards, and ebony side and end slots were done with the Domino. As were the slots for the wooden hold-down clamps for the top.
The finish consisted of a coat of 50:50 medium brown/red-brown TransTint-toned Tried and True Danish Oil. I wiped the toned oil on with a white nonabrasive 3M pad and let it set for roughly 10-13 minutes, then wiped it off. This was allowed to cure for several days, then two coats of Tried and True varnish/oil blend were applied; the top was given a total of five coats. This was allowed to cure for about a month, then a coat of Mylands Antique Mahogany wax was applied with 0000 steel wool.
The project took about 75 hours to complete (including finishing time). Several new things for me were the extended use of the Domino mortiser, rip-cutting the legs on the bias to get quarter sawn faces on all four sides, construction of proud G&G style finger joints in the drawer front, ebony inlays on the bread boards, and use of a more (for me) complex finishing recipe.
Mistakes made? Yeah, one I didn�t see coming. I was trying for (or dreaming about?) the �piston-fit� drawer and cut and glued all the interior drawer guides/runners/kickers accordingly. Then I read that a distinguishing feature of G&G style furniture is a rather large 1/16 inch GAP! around the drawer front to give the drawer front more �presence�. Oops! Well, I sorta recovered by inserting a guide into the side of the drawer to fill the 1/16 inch space between the drawer side and the interior guide, and offsetting the drawer front from the bottom drawer rail/runners by 1/16 inch. For the top 1/16 inch gap, I just cut the entire drawer 1/16 inch narrower. It is still a long, long stretch from a �piston-fit� drawer, but it looks good, and only I (and now all of you) know about the screw-up. Thanks for viewing and I would be happy to answer any questions.
Jim
Re: Thanks Darrell Peart!
Jim Dillon
>As mentioned, here is a better pic of an interesting use for the Domino mortiser. I cut the mortises for the hold-downs with the Domino. Once I marked where they would go, it took maybe 1 minute to cut them all, and they were dead-on. Now let's see. Given the current price of the Domino, that works out to be roughly $100/mortise 8-) 8-). What a deal!! Anyway, it sure makes for a nice polished look with the wooden hold-downs and brass screws. Previously, I had used the figure eight metal clips, or metal elbows. This is much nicer looking IMHO.
Jim
Oops, I should ...
Jim Dillon
>have mentioned that I also used the Domino to attach the drawer handle blocks. Thus no screws showing up on the rear of the front. Sure, I could have used just glue (or screws), but this is stronger and shows the ability to customize the Domino to cut very shallow mortises.
Jim
Nice tables Jim !!
Ray Carson, Lawrenceville, NJ
>Jim,
I love the carved flower top table on your other post. The dovetail work is fantastic. The wood is real pretty too. The square table is my favorite. I love that handle detail for the drawer. Thanks for posting PICS of both tables.
Ray
Re: Nice tables Jim !!
Jim Dillon
>Ray,
Thanks so much. I've never had a creative bone in me, so I rely on the creative inspiration of others. The handles are all Darrells, and I just copied them. I quickly found out that carving is a whole new area to explore, and a LOT to learn. And the sharpening procedures for carving tools are different than chisels, lathe tools etc. I like the petals too. At first, I thought the table top was five separate pieces, but then I realized it was all one piece. I sure took a lot of deep breaths before I plunged in with that first carving cut 8-).
Jim
Hey, that's a sighting!
>Very nice, Jim. Thanks.
Bill White
>Took me a while, but the G & G, Craftsman style, Stickley, etc. is really growing on me. Well done Sir.
Bill
Re: Hey, that's a sighting!
Jim Dillon
>Thanks Ellis! Coming from you, with your broad experience, helps my confidence. It was fun to do and I learned a lot.
Jim
Jim Dillon
>Bill,
Thanks for interest and kind remark. I guess I lean more toward the Shaker, G&G, and Stickley styles in that they fit in with our home style. If we lived in a Victorian style house or something with a little more "grandeur", then I would probably try other styles. Plus, they are great styles to learn on and improve technique.
Jim
Very nice job
Mark From Pasadena
>I made a similar one.
that book is a great one for sure !!
Nice job !
Re: Very nice job
Jim Dillon
>Mark,
I agree regarding Darrell's book. It is actually a wealth of good, detailed, practical info that is applicable to other areas/styles of woodworking. Hope you had as much fun building yours as I did!
Jim
