Thanks Robert Lang!
Jim Dillon
>My wife and I fell in love with this quirky table built by Robert Lang in the December 2007 issue of Popular Woodworking. It was described by Bob as a Gustav Stickley designed table inspired by the Art Nouveau movement in France around 1898. Stickley went to Chicago (from England) and designed this table. It was sort of a transition piece leading, amazingly enough, to his much better known Craftsman style linear designs. While Bob refers to this table as a �Poppy Table�, I have also found reference to it as a Celandine Tea Table.
Bob�s description and workflow were very well described and I generally followed his recommendations. Popular Woodworking offered full scale plans for a nominal cost, so I used them and was amazed at their accuracy and they really helped with all the curves in the piece. Several firsts for me were: use of the Festool Domino portable mortiser, carving, working with mahogany, and multistep finishing.
The table is roughly 24 inches tall and 20 inches wide. The key to assembly is Bob�s ingenious use of five top stretchers centered around a wooden pentagon. This approach not only accommodates the five-sided structure, but creates a very rigid table and still permits securely fastening the top while allowing expansion.
The carving slowed me down by a month while I studied how to do it. While very simple, by carving standards, I didn�t have a clue at first. I quickly found out that quality carving tools are not inexpensive. When done, while not perfect, I was pleased with the result and learned a lot.
I basically followed Bob�s recommendation for finishing. I first applied two coats of Watco Dark Walnut Danish oil (10 minutes each, then wiped off), followed by two coats of Tried and True varnish/oil (three coats on the top). After allowing the finish to cure for a month, I applied a coat of Mylands Antique Mahogany wax using 0000 steel wool. Later, I applied a second coat of wax to the top for a bit more protection.
For such a small piece, there was an enormous amount of rasp and hand sanding work although my oscillating sander helped a lot, especially on all the curves. The total time (including finishing) for the project was about 65 hours. But the effort was worthwhile and we enjoy the piece very much.
Jim
