ADVERTISE HERE - FREE TRIAL
OT Car battery Question
>I drive a Honda CRV and it has a small 12 volt battery. The battery does not hold up well. If I leave the car sitting for a couple of weeks, the batery goes dead. The dealer and I ahve been roudn and roudn aobut this. They tested and found no "Parasitic" loses and no explaination. I am on my thrid and final replacement battery.
What I was wondering is: there is nothing to really know about batteries except 12 volts and Cold Cranking Amps, is there? There is plenty of room in the battery tray. Would it hurt anything to put in a much larger battery? I don't want to get the fragilator cross circuited with the Edisonizer, but it seems like a bigger battery would be a good investment.
Re: OT Car battery Question
>12 volts is 12 volts, regardless of battery size. A larger battery able to deliver more amps would just mean more cold cranking power. The starter motor will try to draw whatever it needs to turn over.
The real issue is the implication that something is continuously putting a load on the battery. The simplist solution might be to disconnect one terminal if it's gonna sit for a while, or install a cutout switch.
Another idea is to install pedals or always park pointing downhill.
Clint
>Barry,
Batteries have a size, voltage, Cold-cranking amp rating, and a Reserve Capacity rating. The higher the last two numbers, the better.
I usually put as large a battery as will fit into my trucks. I have a one ton flatbed with V8 engine that sat for 9 months and still started up OK. Of course, it's a 1976 model and I'm pretty sure it has no fancy electronics that draw power when idle.
As long as the voltage is the same, I can't think of any reasonable scenario where a larger capacity battery would hurt some component, other than your pocketbook. Current isn't like voltage - regardless of the capacity of the battery it will not deliver more current than the circuit demands. The existing fuses in the car should protect everything downstream, regardless of the battery size.
I did read that the alternators on some new cars will not charge a battery from a low state, but just maintain it. I'm sure they did this to save money, but it stinks. It's possible that a higher capacity battery will not be able to charge it to its rated capacity, but I don't know.
It's hard to imagine that your car is not drawing ANY current when everything is turned off. Things like clock, alarm, auto door lock sensors, etc draw power. To test, disconnect one terminal and use an amp meter to complete the circuit. I have no idea what is normal for your car, but your dealer should be able to find that in the books.
Maybe aliens are sucking power out of your battery at night. One idea even wilder that that - I can imagine a case where a component, wire, or contact is temperature sensitive such that it shorts out when the temperature drops at night. Checking the current draw at the dealer's in the day time would not show the problem. This would be tough to catch.
If you have excessive current draw from any source you can buy a cutoff switch to fit between the battery and the car. These are sold as disconnects for maintenance and theft deterrents. The have a big plastic key that you can remove and take with you. You would have to reset any digital clock after using one.
Another thing you can do if your car has to sit is put a battery tender on it. This is a smart low-current charger which will bring a battery up to charge and keep it there. I rotate one between some of my 4-wheelers and mowers in the winter months. Could even mount a jack near the front of the car to plug one in without opening the hood.
Bill Howatt
>How many years do you get out of a battery? Should be at about 5 years or more.
There have been cases of some faulty gizmo intermittently turning on and draining the battery. One case I heard of was a power window relay which really pulls the current when the window is all the way up or down. Another case had to do with a fuel pump relay that caused the pump to run.
If it is intermittent it could be very hard to catch. What happens if you pull the battery out when you know it won't be used for a couple of weeks? Will it still go flat?
The other thing that can kill a battery is overcharging which causes the battery to get too warm and buckle the plates.
If there is no other problem, I would replace the battery with a larger capacity one that physically fits into the tray.
Bill
Ken Oakley-Sunny St. Cloud, Fla.
>My wife has a Honda Accord and even with the ignition off the electic fuel pumps runs on and off to maintain pressure to the injectors. If you leave the car for long periods of time this might be the cause of the battery going dead
Larry Clinton At Frankfort (Central)., Indiana
>No question - you can put any 12V battery in the vehicle that will fit in the case without any problem - PERIOD. However, I would also have the alternator tested to see if a diode has gone bad, it may be you aren't properly charging the battery. If this is the case a new battery is not going to cure the problem. As others have said, using a multimeter to see if there is a current draw is quite easy and takes just a few minutes. I have had vehicles that had improperly functioning dome light, glove box light etc. that did not turn off. Some of these can be hard to detect - glove box / trunk lid / under hood lights can all be on - hard to see when they are covered. Other possible current draws may be from bad delay relays for the dome light, key light etc.
Frank in Forest Hill
>Barry,
Both My son and I have 05 accords..... we love the cars but both batteries have failed in less than 3 yrs each. We just replaced them with non oem units and time will tell.
Frank G
Jesper, Denmark
Jesper, Denmark
>You have had lots of good advice here. let me just add that the old, unsmart alternators charged with 13.7 volt. New smart ones - I have one on a boat, starts out with 14 volt and then drops down to 13.7 after the charge is full.
You can check the charging with a voltmeter across the battery poles with the engine running.
Anything under 13.7 volt is no good.
if you use a disconnect switch, you will have to re-set the clock and probably also the radio safety code and maybe some other code for the car's computer gizmos.
Lee Schierer - McKean, PA
>My boat battery will go dead in about 2 weeks if I leave teh fuse in the radio circuit. The lighed display in the radio will drain the battery down enough so the boat won't start. Since we seldom use the radio it was a simple matter to pull the fuse.
You car probably has something running that is draining the battery. I would check the trunk light and the under hood light to make sure they are turning off when teh lids are closed. Having the dealer check the current draw with the car turned off against a similar car may reveal whether you have a problem or not.
Lee
Kevin Rabenaldt
>If you have something draining your battery at a trickle pase, try this.
Get a 12 volt test light (Cheap at autoparts store).
Disconnect the positive cable.
Connect the test light in series between positive post and positive cable. Keep your key out of the ignition.
If light burns, then you have something putting a drain on the battery. With the test light hooked up, remove one fuse in the main fuse box at a time to see when the light goes out. When it does, then you have narrowed it down to what the fuse protects. Hunt it down from there. The auto dealer should be able to do this and would answer your question pretty quickly.
GalenV
>Did the service people ask you about your driving habits. I know if you do a lot of small runs to work or shopping you can drain a battery over time as you do not run long enough at any time to fully recharge the battery. Not sure how many times you let the car set for two weeks but if you do that often and never drive long enough you may run the battery down. Last service trip they said my battery was weak (05 Nissan). I had let car sit and lots of start stop short trips before I took it in. Drove a good day trip distance and had them recheck and battery was fine!
I assume they checked to see if the electric cooling fan was cycling correctly as it runs after the car is off.
Power windows, powered sun roof, seats, seat heaters,tail gate do all heve the potential of not shutting off. My power seat has hunted for position twice on it's own but they could never duplicate when I took it in.
I have had my car set for several months (hospital stay) and all the small loads, dash monitor memory, radio/clock, security, door sensors, etc. have never gotten me to the point it would not start so the drain to these must be low.
Had a Chevy truck the radio played when the truck and radio were supposedly off. They never could find the answer and figured a wiring harness was shorting but never had the whole truck gutted to try and find. New radio did not fix it!
Odd things happen for sure.
