Question for old Craftsman TS owners
Tim Greif - West of Chicago
>OK, a question about old Craftsman table saws, not old owners of Craftsman table saws, but then again, that may be one and the same.
I'm restoring a probably 30 year old TS that my neighbor has given me for my son. It was in pretty rough shape but is coming together nicely. Anyway, my delta contractor saw has the motor hanging off the back with the weight of the motor providing the belt tension. On the Craftsman, there is a similar, although less leveraged motor mount arrangement where the motor mount pivots at the bottom. But at the top of the mount, there is also a machine bolt/washer/lockwasher which can secure the motor position to the fixed part of the mount attached to the trunion.
Is that machine bolt supposed to be left loose so the motor weight provides the belt tension? If you fix the motor position, the belt tension changes as you raise or lower the blade. I'd assume the bolt should be left loose, but then why is the bolt there at all, especially with the lock washer? You can't remove the bolt completely since the pivot arrangement would then allow the motor to move sideways and change the pulley alignment.
The PIC below is not our saw, but it's the same. The arrow points to the machine bolt location.
I've never owned a Craftsman, so I have not a clue. Feeling a bit puzzled here, West of Chicago.
Re: Question for old Craftsman TS owners
George Koch
>Tim, In the 60s we use to raise the motor and tighten that bolt when we moved the saw from job to job. I don't know if that was Sears intent on not. George
John E in SC
>I have a probably 20 year old Craftsman TS, which looks about the same as the pic. I can't recall that bolt exactly, but I do know the motor on mine is "loose" - in other words, you can just pick it up to release the tension off the belt. I put one of those adjustable link belts on mine a long time ago after being sold on it's virtues at a woodworking show, but honestly can't say I've noticed much difference. May be a little quieter, but that's about it. The motor weight seems to provide ample tension to the belt. I can't recall it ever slipping.
One other thought - if yours has the plastic wheels to raise and tilt the blade, it's well worth replacing those with metal ones - they're much easier to use.
Good luck,
John
John
>It is supposed to pivot on the bottom. I only used to use that bolt to lock it down. I replaced my fence a long time ago, that particular fence was not very good. I really don't miss having that saw.
The Woodruff keys had a tendency to come off of the pulleys. I used a spot of super glue to keep them stationary while I tightened them down. Chuck from ND had an idea that he sold to Penn State for 4" dust manifold for the bottom of that saw. I used to use a couple of piece of wood in the interior bottom and a plywood cutout to hold a large flat dust hood on the bottom. I used a variety of things to block off the back - none worked well.
I had one...
Bartee
>I had one of those saws.
I put a bolt in the threaded hole and snugged it down. Not all that tight. It seemed to help with some of the vibration.
It will probably work just fine with it.
Do put on the link belts. They do help with vibration and less slippage.
You WILL definitely want and new fence....
This was my setup.... Click on pic for more pics...
From Table Saw Base Jan 2005
Can't tighten the bolt!
Lee Schierer - McKean, PA
>The motor has to be free to pivot as your raise and lower the blade. If you tighten the upper bolt, the motor may stick when you lower the blade and the belt will slip.
I have a similar saw and I would also recommend replacing the fence, the drive belt to a link belt and the cast pullies to machined ones. You will also need to do an alignment of the blade to the miter slot, but will be wasting your time trying to align that fence to the miter slot. The miter gauge is okay, but don't rely on the stamped angle indications to be accurate. I replaced my miter gauge with a Kreg miter gage last year.
Use a 24 tooth thin kerf ripping blade when ripping and the saw will perform well.
You can box in the bottom to collect dust with your DC and use a magnetic vent cover (Get them at the blue borg) to seal the slot at the front. I trimmed a second magnetic sheet to fit around the motor mount when the saw is in the 90 degree position. It seals up much of the space so the suction of the DC will keep most of the sawdust from flying out the back of the saw.
Lee
I Had One Also
>Good Afternoon Tim,
I used mine for a few years before buying a Jet Contractor Saw. Gave the Craftsman to #1 son, who solved the weakness of the motor by burning it out. I too, hated the fence. Completely worthless. the motor wasn't particularly strong, but it worked it worked with you if you worked with it. I experienced almost no vibration problems. I did not try to tighten the bolt. Trying to tilt the blade to 45 degrees was a real workout. Yet, despite all the negatives, I did like the saw but was not sorry to see it go. My #1 and #3 sons used it to put in a finished basement which included a wet bar and maple cabinets. I think the saw decided to die when it sensed all that hard maple it was going to rip.\
George
Pete LaBelle
>My dad has a saw like this. Had problems of the pulleys loosening up all the time. Replaced them with turned steel pulleys and haven't had a problem since, AND the saw runs with very little vibration now. Old die-cast pulleys were obviously worn on the ID and out of round on the OD.
Quote from manual (plus  and *LINK*)
Rod Peterson -- Ormond Beach
>Here is an excerpt and a picture of the pertinent details from an old (roughly 1960s) Sears saw manual. The inner workings of their saw were essentially unchanged for decades, so you should feel safe in using this information.
f. Adjust motor mount tension as follows:
  • This adjustment is necessary to prevent motor vibration and permit motor mount to move as its position is changed when saw blade is raised or lowered.
  • The adjustment is made by tightening (or loosening, as required) a screw that secures the slotted slide on motor base to the support assembly. (See figure 13.) This screw controls the pressure between a spring washer and flat steel washer.
Caution: do not tighten screw to a locked position as it will be sheared off when saw blade is raised.
Here is a link to the PDF I used for the text and images: Old Sears TS Manual (it's a 5mB file, so don't click if you're on dialup and impatient).
Rod
I had one too - DANGER
Neal in San Jose
>That fence is worse than worthless; it is dangerous! The worst kickback I ever got was because that fence CAN and WILL lock down out of square. Not a big deal except for ruining the cut when it falls away from the blade, but when it locks down closer to the blade in the back than in the front - kickback is almost certain. There is a reason that almost all rip fences in the last 20 years or so are of the "T" square design and only lock down at one end.
I Had One, Too
Mike Fitterling
>The motor was a bit anaemic but I solved that by putting a 2hp on it (frame 56). That motor turned out to be just the right weight to keep the pully tensioned properly so there was no need to use the top bolt.
Perfect answer - thanks Rod
>That clears it all up. What I thought was some kind of a lock washer is in fact the spring washer they refer to in the manual.
I downloaded the manual you linked to as well. That will be a real bonus. It's close enough to our saw that it will be a real benefit. Our model is 113.298031 so I'm not sure if it's older than the one in the manual since it has a lower series number.
Thanks again Rod.
Great—now I have work to do…
>Putting the manual on my web host and coding a link to it works so well, I'm going to have to incorporate it into the file at my site about upgrading a Craftsman TS. Now where did I put that file?…
I'm glad it was what you needed, Tim.
Rod
Re: Question for old Craftsman TS owners *LINK*
Chuck in ND
>Here is a link for the dust collection that JL mentions.
http://woodchuck1957.googlepages.com/home
Re: I had one...
Lou
>What fence would you suggest as a replacement?
