>My old hands hurt when I try to grip screwdriver handles, clap handles, etc. to tighten things. I've been thinking of adding something on the handles like the material used on golf clubs (BTW I don't play that game). Maybe ya'll know of something else that's even better/cheaper/just as good/whatever.
Just looking, thinking, asking for suggestions.
...and I've already had the Red Green double sided duct tape thought.
My first thought is foam water-pipe insulation. Ya know, that foam, hollow cylinder stuff in the "save-the-earth-or-we'll-all-die" department of Home Depot, etc.
The foam may be too soft for tool handles. Dunno. I'm not nearly as old as you and, therefore, not nearly as wise. ;^)
As a long time hand patient and with friends with worse problems, you may be on the right track. When I developed hand pain and numb fingers some years back from too much computer typing, the therapist told me to apply a foam grip to tools and such to increase the diameter and make it easier on the hands. Note that there are a lot of stretching exercises and therapy that might help - you might try to see an hand specialist or at least search google for some advice.
I visited a friend last night in the rehab hospital who had a stroke to add to the other problem of breaking his neck and spinal cord about 35 years ago. He uses a soft rubber material around things like paintbrushes and fork handles. This is the only way he can use anything with his hands since his fingers don't work. The material he had was a relatively firm red foam, about an inch in diameter, with a hole down the middle small enough to grip a fork handle.
A quick google search found a number of grip suppliers, including the one in the link below. Click on their 'smooth foam grips' picture and follow a link there for more information on various material types.
This also has a good description of materials for specific uses, under 'foam tubing': http://www.grabongrips.com/?gclid=CLHS6tr9hZcCFSCcnAodLBrC-A
Also, I see these from several suppliers: http://www.medfordtools.com/hammers/stiletto_grip.html
I can my friend later today and ask him where he gets his grip material. He's had a lot of experience with this over the years.
The current issues of FW has an article on this exact problem. I just received it yesterday and haven't read it, but might be worth looking at.
I'm only 46 and can't hold a paint brush for more than a couple minutes before my hand cramps up and/or becomes painful. Holding something like a paint brush for any length of time is tough to do. Holding a tool at the lathe is another example.
>If you can find it at a safety store....Coban is a self sticking wrap used in first aid kits to wrap an injury...its similiar to tennis racket wrapping.
Second is found at a contractor roofing supplier....look for a "cured" rubberzed flashing tape ( 6" wide rolls ) thats used to strip in a metal/rubber roof detail like near a flat roofs rubber to a metal drip edge. Its about < 1/8" thickness and Firestone/
Mulehide/ Carlisle made a great product that I still use even today. Its great for applying to 5 gallon bucket handles to beef them up and hundreds of shop uses. Its a peel n stick product so you can cut it to whatever shape or length you want.
>Verey timely question. See the article in the very newest Fine Woodworking Mag. It is called, "Don't suffer for your craft" or something like that. Page 80. Guess who wrote it! Rockler makes a slip on foam clamp handle
>I wear a pair of Wells/Lamont nitrile-coated gloves. They are very thin and tight-fitting but extremely durable. They multiply my grip strength, especially for clamping, and, as a bonus, are pretty much impervious to splinters. The advantage is that I don't have to put stuff on each and every handle in the shop.
>My favorite screwdriver has a spherical ratcheting handle. Easy to put in the palm of your hand and wrap fingers around it. Very comfortable and easy to get a great grip. Of course, that only addresses the screwdriver issue.
Someone makes a liquid rubber for dipping handles into. You can build up layers to get the thickness you want.
>You might consider, where appropriate, adding more leverage by "widening" the handle - cross-drilling clamp handles to add a handle like a vise handle, for instance.
