ADVERTISE HERE - FREE TRIAL
computer tower in shop
wooden leg
>I am getting ready to install my old tower in my shop. I know that some of you have computers in your shop. What have you done to protect your systems? Thanks in for all you do. Dave
Re: computer tower in shop
It would be a little Dust Collector
Dustmaker Mike
>I am not sure but when I open computer cases that have just been in the office, they are dust collectors. I hate to open one that has had someone smoking around it because they are just nasty. i think a laptop would be a better choose for a shop. If you have the tower and can keep it in a cleaner area of the shop with a cover over it when not in use it should do ok. What kind of monitor are you looking at using? That may be a bigger problem.
I use my laptop in my shop when I am in it with no problems.
Re: It would be a little Dust Collector
>I saw a case once made for computers in dusty locations. It had what looked like home furnace filters on the sides to keep out dust and allow air exchange. Watch for dust accumulating in the vent slots of monitors, even LCDs. Thin foam filter material taped over any openings would help. Also, an optical mouse to keep from clogging the ball and cover the keyboard with plastic wrap.
Paul Woolson
>I did just that for mine. Basically a wooden cube with a plexi front and one side paned built to accept a furnace filter. The other side has a small fan in it blowing outward. (I found a really big computer fan for this as it ran pretty silently). You'll need to keep the air moving across the computer or it could overheat and give you big problems.
Bill Howatt
>Build a box with a couple of pleated furnace filters to clean the air somewhat.
You can also get monitoring programs, one may have come on the CD with the motherboard/computer, to monitor temperatures, voltages and fan speed. It usually is possible to set alarm points so the PC will beep if the CPU, or motherboard gets too hot. You can also alarm on voltages and fan speeds.
Heating can indeed be a problem but paying attention to it is all you need to do. I would schedule a dust blow out every month or two until you see how fast it collecting in the box.
I have all of my PCs in the basement but not inside my basement shop and the dust problem is not an issue at all.
Bill
Larry Marker
>I have a computer in the shop and have no problem for three reasons.
First, I don't let a lot of dust get into the air. I have a basement shop and letting dust escape into the house would be "un-cool". Also, I have emphasema and letting the air get full of dust is just not in my plan.
Second, I leave the computer off except when I use it. That way the fans are not running and what little dust gets into the air doesn't get into the computer.
Third, I leave the case screws off and can pull the side off the machine easily and do so every couple months to make sure it is staying clean. It stays cleaner than the one I have upstairs in the house.
Larry
Six years . . .
steve mackay
>I moved our old machine into the shop 'bout six years ago. No cover except for it being tucked up under the bench. Still works great. Won't BURN CDs any longer but WILL read everything. Only beef I had was the key board. Installed a sliding key board drwer under the bench with a bit of old jeans to flap over it so saw dust didn't settle into it.
DizD
>I put a Shopshield on mine about a year ago - so far so good. It's keeping the Bluegrass Mix audio streaming - that's my measure of success.
steve mackay
wooden leg
>I will be using a flat 22" screen. It will be used mainly for drawing. Thanks Dave
Re: ?
DizD
>Sorry. Shopshield is the brand name of a computer dust cover - you can google it.
