Re: Way OT - car heater question
Bill Houghton, sunny Sebastopol, CA again
>If the response is more or less instantaneous, it could be a vacuum problem. Some modern heaters run the outside air through a separate set of ducts from the heated air, and switch, if you will, downstream from those ducts. Our 1996 Volvo does, for instance - if you change the temperature setting on the heater, the temperature of the air from the vents changes immediately. The switch between cool outside air and outside air that's been heated may well be vacuum-driven.
I don't know much about Mitsus, but on a lot of modern cars, the systems are so complex (with the best of intentions...) that you can spend half a day just understanding them. She might want to cruise into the local library and see if there's a Chilton's or Motor manual that discusses her car's HVAC system in enough detail to dope out what might be causing it.
Wandering OT: my all-time favorite useless car HVAC feature was on a Mazda that we rented on vacation: the vanes on the dash vents had little motors to swing them back and forth when you had the air conditioning or heat going, so as to distribute the air about the cabin. I can just imagine diagnosing problems in THAT system.
