Drying time for spray on spar urethane
Dan Mitchell
>I made a base for a lamp out of MDF & padouk veneer I cut on the bandsaw. In order to prevent the padouk from losing its orange-red color, I applied 4 thin coats of Minwax spray on gloss spar urethane, which blocks UV. The finish looks great, but ~36 hours later, it is still tacky. Piece has been at room temp all this time. Is this normal? Anyway to speed up drying? I'm considering the finish for another padouk project, but am concerned about the dry time.
TIA
Dan
Re: Drying time for spray on spar urethane
Antioxidants
>It sounds like your padauk might be interfering with the curing of your finish. This happens all the time with rosewood and varnish. The padauks are in the Genus Pterocarpus, which has similarities to the Dalbergias (rosewoods), so I'm guessing the same kind of chemistry is going on here. With such woods, you need to put a sealer coat of something (shellac, vinyl sealer, etc.) on before proceeding to urethane or other varnish. Try sealing a sample and then finishing with your spray varnish to see if I'm right.
Ellis is correct........
Howard Acheson
>.....padouk contains oils that interfere with the curing process of oil based finishes. You need to create a barrier between the wood and the oil based finish. Dewaxed shellac is your best bet. Be sure to use a dewaxed shellac or you will not be able to use a urethane topcoat. The natural waxes in shellac will make for weak adhesion of poly varnishes.
>I doubt that any finish would prevent the color change for too long. Suggest that it be stripped and hit with spray can solvent lacquer. I did a padauk mantle with solvent lacquer with no problem.
Clint
Meant to add....
Howard Acheson
>... that you will need to use a chemical paint stripper to remove the uncured finish. I recommend using a stripper containing methylene chloride for the best results.
Dan Mitchell
>An interesting point is that the base has a piece of pine about 2 x 2 x 2 in the center to facilitate attaching it to the bottom of the lamp, the urethane on this pine is also a bit tacky. Not as tacky, but close, and even though I didn't apply the finish nearly as heavily to this center mounting bit.
I see on the can it states that if you don't apply a 2nd coat within 2 hours, you need to wait 72 hours, sand lightly, then apply again. I wonder if this says anything about cure times?
I'll definitely keep the oil thing/finish compatibility in mind the next time I select a wood. This is beautiful wood, in its red stage, but if it's only going to get brown & is a PITA to finish, it doesn't seem to be worth the trouble.
I REALLY don't want to have to strip this thing & refinish it. For one thing, it LOOKS really nice, not even runs, may be a 1st for me! I'm in no particular rush to assemble this lamp. Is the finish likely to harden with time, say, a couple weeks? I wonder what the effect of baking it at low temp, say, 150 degrees would be?
I hate finishing...
Thanks for the replies.
Dan
I should add that
Dan Mitchell
>I sprayed the bottom of the base, which is bare MDF, very lightly as well to seal it a bit, in spots it's also slightly tacky.
Maybe it'll dry...
>... hard enough for your purposes, Dan. My hunch is that it will stay tacky for a while and never dry hard.
Re: Maybe it'll dry...
Dan Mitchell
>Well, it is just the base for a lamp, not really likely to face too much abuse. "No longer sticky" should be sufficient for this application.
So, you don't think baking if at a low temp would be of any use?
Wood ought to come with instructions... ;-)
Dan
Ken Platt (granby, CT)
>For what it's worth -
I got caught on this one with an ipe/oak table top, and Minwax wipe-on poly. I too couldn't bring myself to do the work of stripping, so I kinda just kept rubbing the ipe part until no further finish seemed to come off. I think what I ended up with was just a real thin coat, but anyhow it looked and continues to look good, and I didn't have to strip.
This might not work so well for paduak - ipe almost doesn't need a finish if you sand to a high grit and polish it, so I may have been lucky there.
Ken
