Source for lighting fixtures?
>The LOML would like for me to build a pot rack lighting fixture for our kitchen. I was figuring on making it roughly rectangular. I was going to either use metal rods or doweling attached to sides. The pots/pans would be suspended from the rods/dowels using S or J hooks.
I don't want to make it 4' long - I was thinking about 3' x 2'.
They sell the 2' x 2' fluorescent fixtures in a troffer (to fit into a suspended ceiling) that use the bent fluorescent bulbs. They also sell 2' fluorescent fixtures. They may sell some 36" fixtures - but I don't really have a reputable source. I would like a lot of light. So, should I use the 2' x 2', use several 2' fixtures or try to find some 3' fixtures. I was planning on cutting a diffuser panel to fit the fixture. I don't mind putting other types of lighting fixtures in either.
TIA.
Re: Source for lighting fixtures?
Fred Davis
>They make 36" fixtures and for the most light in a florescent, go with High Output (HO) in the 120 V. range , rather then the more common 240V.
These fixtures in multiples of two tube strips 48" long and mounted in a Ash box to match cabinets and having off white diffusers that drop down a inch below the face frame on the box is what I used in our Kitchen, which Elaine referred to as the "cave" before the redo.
FredD
Here's an example....
>of a simple idea using 36" T12 fluorescent fixtures.
Clint
Another example....
>using incandescents on a dimmer.
Clint
Clint, Fred - thanks for the ideas, but...
>I was wondering where to find the 36" fixtures. Our local HD does not seem to have them. I suppose I could try the Lowes over in Murphy, but that's a bit of a drive. The local lighting store just carries high end stuff. All I want is a couple of 36" strip fixtures I can mount in my own base.
Re: Clint, Fred - thanks for the ideas, but...
>It's been a while, but I got my 36" fixtures from an industrial lighting supplier. outwaterhardware.com is another source.
HERA "SlimLite" FLUORESCENT LIGHTING - Six sizes from 10" to 60" Long
The "Sales Pitch": This is simply a beautiful lighting system, and one of our favorite items!
Use: The SlimLite is ideal for display cases, store fixtures, long shelf runs, accent pieces, point-of -purchase displays and furniture.
A fluorescent light so compact and so slender that it fits in even the most hard-to-light areas in furniture, displays or under cabinets.
The sub-miniature electronic ballast is hidden inside the bottom of the fixture, so there are no external boxes whatsoever!
Installation: Easy to install with the enclosed snap-in-bracket system. Different sized fixtures simply plug together with various length
connecting cables allowing for continuous rows of light up to 35 feet long. Fixtures effortlessly flow together - creating continuous lines of
fluorescent lighting to fit any space. These are the highest-quality, highest-output lights, offering extremely "low heat".
Features: T-4 and T-5 tubes are included with each fixture. Replacement bulbs are readily available at lighting stores and home centers.
Modular connecting system makes it simple to create long, almost unlimited lines (200 watts per run) of fluorescent lighting.
Plugs into a standard electrical socket.
Instant starting, Tri-Phospor lamp. Quiet and flicker-free.
Extremely long life cool white (4100K) tubes: T-4 tubes last 10,000 hours or T-5 tubes last 20,000 hours
Available Lengths: 10", 13", 20", 35", 46", and 58" Long
COLOR: White
NOTE: See following page for Cables, Connectors, Power cords, and Junction boxes
PART # EXACT
LENGTH WATTAGE TUBE
TYPE HEIGHT WIDTH
LIT-ES10 10" 7 watts T-4 1-1/4" 11/16"
LIT-ES13 13" 10 watts T-4 1-1/4" 11/16"
LIT-ES20 20" 18 watts T-4 1-1/4" 11/16"
LIT-ES34 34-7/8" 21 watts T-5 1-5/16" 29/32"
LIT-ES46 46-3/4" 28 watts T-5 1-5/16" 29/32"
LIT-ES59 58-7/16" 35 watts T-5 1-5/16" 29/32"
NOTE: One Power Cord PART #: LIT-SPC is required for every run.
John E in SC
>See if your town has an electrical supply house - a place where contractors and electricians buy their stuff - not a big box store or a "lighting" store that caters to homeowners. They will likely have what you're looking for, and if it's like here, you might be surprised to find that comparable (or better) stuff is cheaper than Lowes. (Learned that lesson the hard way!)
John
Curly Smith
>Home Depot carries two different 3' fixtures:
two bulb fixture:Lithonia Lighting 3 Ft, 2 lamp ($23.88)
single bulb fixture: Lithonia Lighting 3 Ft.1 Lamp ($12.67)
Your store may not stock them but they can order some for you.
Fred Davis
>Regarding your statement " I would like a lot of light" is possible with High Output (HO).
Conventional ballasts are not noted for a "lot of light" neither are the "cool white" tubes most stores stock. The "warm light" tubes give even less light.
FredD
Thanks for the sources.
