Fixing clouded laquer
J.C.
>New age cabinet maker looking for a recipe for an old school hand rubbed finish to go over catalized laquer. Time frame is a most. This is a service problem. Need to be resolved before Xmas. Please help.
J.C.
Re: Fixing clouded laquer
Bill White
>Not much info to work with. Any chance for pics? What's the wood?
Dark, light, new, old?
Bill
Dick Coers
>With the information given, I would suggest using abralon to get the sheen you need. No other materials needed, a little mineral spirits if you want to wet sand with them. Start with 600 silicon carbide sandpaper if the finish has orange peel or needs to be leveled. Any of this will be tough if doors and internal surfaces need to be addressed.
I'm confused
Bill Tindall, E.TN
>I can't relate the title to the text- cloudy finish and how to get hand rubbed. What do you want to know?
Re: I'm confused
Dan Donaldson
>I don't know the answer to the question, but it sounds from the description, that the lacquer has moisture trapped in it causing a cloudy appearance. I read somewhere about a fix for that condition, but can't remember where. Try sending a note to Michael Dresdner and see if he answers.
Fred Davis
>Sounds like Lacquer blush to me and Dan is right about that being trapped moistue.
Also sounds like a good time to read up on a expert doing that particular repair and that would be Greg Williams in the December issue of Woodshop news who is the Sales and Technical Advisor for H. Behlen and Mohawk Finishing product.
FredD
Re: If it is trapped moisture... *LINK*
Dale Lenz
>you can spray a very fine straight lacquer thinning on the finish and release the moisture. This assuming temp is say >65 degree F and RH is < 65%. See link below and look for contriber M.
Blushing/Cloudy Lacquer Finish
Re: More info
J.C.
>The wood is black walnut, rustic. The problem seams to be on the more open and end grain wood. It was suggested that the wood was high in moisture at the time of building and has shrunk leaving white spots in the laqure. The wood around the knots and wild grain seams to be just fine.
A wax, hand rubbed finish with three or four coats was recommended. This was the only idea the homeowner would listen to. She does not want the overspray going thoughout the house. Not that I blame her. Just the time I have to work with does not allow the demmo and refinishing that would intell. I do not know of a good recipe for the wax finish.
The help in this matter is greatly helpful and appreciated.
Re: More info
Steve Schoene
>While some blush remedies are sprayed you don't have to do that, especially since that isn't something the client will tolerate. But you may achieve decent results with a damp (not wet) wipe with denatured alcohol.
Trying to mask the blushing lacquer with wax either won't be effective, or if it is it's because so much wax was left on the surface that you would have a very vulnerable surface--even more than the typical wax shortcomings.
Re: More info
Fred Davis
>I can't imagine a Lacquer blush being fixed by wax , but the client sounds like one to stay away from to me.
Puting on some blush remover or retarded lacqure thinner you might point out is no more odor causing then her nail polish and remover is .
FredD
Re: ?
Dale Lenz
>Are we seeing white spots or white specks, size of table pepper?
Re: ?
J.C.
>White streeks with the grain.
Re: ?
Carol - now back in Dubuque, IA
>Delamination of the lacquer? Is the surface rough?
I remain confused
Bill Tindall, E.TN
>"Just the time I have to work with does not allow the demmo and refinishing that would intell." What does this sentence mean?
You don't have a simple problem with a trivial fix, I suspect. If you took the time to precisely define the problem and the boundaries to fix it, it would enable a more useful response. A picture would be helpful. Consulting with an experienced local user of whatever was used would be more helpful still. Diagnosing this problem will likely involve knowing a great deal of detail about the finish and how it was applied.
Many have jumped to the conclusion that blushing is the issue and that blush remover is a solution. Note in original post that the lacquer is catalyzed. I have never tried repairing cat. lacquer but I suspect it can' t be done. The whole reason to use cat. lacquer is to create a solvent resistant and otherwise durable finish.
To fix blushing the finish must be resolubilized and a cat. lacquer may not resolubilize. The fix has nothing to do with "releasing trapped moisture". Blushing is caused by condensed water vapor precipitating the lacquer from its solvent system to make a crazed film. Squirt some water into lacquer to recreate the effect.
That said I would still try spraying a squirt of "blush be gone" on the problem area and see what it did. Any of the finish repair companies sell an aresol can of blush remover, or one can make it yourself from lacquer retarder solvent.
Are you proposing to strip this finish and then wax the piece, or are you hopeful that waxing or rubbing over what ever this problem is will fix it?
Re: More info
Fred Davis
>One other observation I would make is the statement about three or four coats of hand rubbed wax.
Bob Flexner and Mac Simmons and other finish gurus over the years have stated , that one coat of wax is all you can get on a piece until the first coat is eventually buffed off in cleaning and dusting.
Because the additional coats do not stick to the first one.
Just because the Lacquer is catalized and I don't know how you know this from looking at it, does not mean that a blush caused by water vapor not respond to the traditional fixes.
Blushing is caused by the Lacquer drying to fast and trapping moisture in the air , under the film. Same thing happens with a water ring caused by a glass set on a finish that sweats.
The fix when applying is retarding the drying by use of a slower thinner when spraying or Lacquer retarder added to the Lacquer.
In the shop I have in the past occasionally got lucky and removed the blush by simply spraying another coat under warmer , drier conditions.
Since I built this last shop and and totally conditioned the air Summer and Winter. this no problem longer happens.
FredD
