OT - Baffling Plumbing Issue....
Brian in Sandusky, OH
>I installed flood-safe connectors on our toilets a couple of years ago.
These are the lines that go from the wall to the toilet.
In theory, if there is ever a huge gushing leak, they will detect the leak, and automatically shut off the water.
But here's a funny thing that's happening.
If I turn OFF the main, the line will leak. When there is NO pressure in the water lines, the water in the upper reservoir will drip slowly onto the floor.
But then when I turn ON the water main again, adding pressure to the system, no leaks!
It's not a huge deal, as I'm going to replace the line tomorrow.
But what in the h*ll could cause this?
Leaks with no pressure, and NO leaks WITH pressure. I'm assuming that it has something to do with the flood-detecting shut-off valve being faulty.
I'm am an OK plumber...certainly not advanced, so maybe this is obvious and I'm missing it.
