Cutting a blind opening for a door...
Scott in Douglassville, PA
>Hi, all -
Not sure if my use of the word "blind" is appropriate, but I need to cut an opening for a door in a single piece of wood. The plans call for marking out, and cutting with a jigsaw. I can't cut a straight line with a jigsaw to save my life, so I'm looking for alternatives.
I'm thinking of roughing the opening with a jigsaw, then using a straightedge and a pattern bit in the router to clean the edges up. This seems like a lot of work, but I can't think of another way.
The panel is already sized and joinery finished, so I can't rip and crosscut the opening and reglue the panel.
Ideas?
Thanks,
Scott
Re: Cutting a blind opening for a door...
>Good Afternoon Scott,
Using a router to flush up/straighten out the door opening should work well. All you need do is a little hand work on the corners.
George
Fred Davis
>Clamp a straight edge to run against with your jigsaw, no corner cleanup that way
FredD
Alexander Grigoriev
>Or use turner's (sticky) tape to stick the straightedge on, if the clampls can't be used.
