What size plu cutter...
Brian in Cheyenne
>would I need for a #6 Counter sink? There appear to be three sizes, 1/4", 3/8" and 1/2"....
Re: What size plu cutter...
Plug Cutter!!
Brian in Cheyenne
Dale Lenz
Re: What size plug cutter...
Dale Lenz
>What is the diameter of a #6 screw head? That is a deciding factor. It's been years since I used plugs but I think I make a 3/8" counter bored hole. Have fun.
Glenn Madsen near San Francisco
>I used the drill bit and plug cutter combination I had to determine what to use. 3/8" is a common setup. The Veritas cutter is quite nice.
Matching to a screw size is nice, but I'm not QUITE that careful. Matching grain orientation on the face plug is important, though. Take that care.
Bill Houghton, sunny in Sebastopol, CA
>According to the handy chart I just got from a famous woodworking magazine attempting to get my subscription, a traditional #6 wood screw has a head a little larger than 1/4" (9/32"), while a production #6 screw has a head 1/64" larger than 1/4". So it looks like a 1/4" plug cutter is out. By the way, though I don't know the exact dimensions, #6 drywall and deck screws have heads much closer to 3/8" than to 1/4".
3/8" should do the job for you; in fact, it will cover everything up through a #9 screw, at which point you need to step up to 7/16" (rare) or 1/2". You need to counterbore your hole to fit the plug (that is, drill a 3/8" hole with straight sides deep enough to hold the screw head and take enough plug that it won't drop out). I'm not sure all assembled screw/countersink/counterbores for #6 drill a 3/8" hole - check yours, if that's what you're using.
My preferred method is to use a 3/8" brad point drill first, then drill the clearance (shank) and pilot (threaded part) holes with regular bits. This gives a good clean edge at the wood surface. While the base of the hole is not countersunk, this has never been an issue for me, but if it worries you, either use round or pan head screws or buy one of those all in one bits that drills the counterbore, shank, and pilot hole all in one motion.
You didn't ask, but now that I'm started...
I don't cut the plugs the full depth of the stock from which I'm cutting them. This leaves them stuck in the hole. I then use a small screwdriver (anything would work that's strong enough) to reach down beside the plug and snap them off. The broken grain gives me a VERY clear indication of grain direction, so I can line it up with the grain on the piece I'm plugging.
Don't drive the plug all the way in, especially on outside work - you want the screw to have some headroom if there's movement. In response to your question, "How do you know this?" I will just say this: If you ever come visit, see if you can spot the screw locations on my porch steps; as long as the sun's up when you visit, it won't be hard.
Once the glue has dried, I take a sharp chisel, bevel down, and knock off most of the plug, pushing in the uphill direction of the grain (as the chisel goes forward, the grain should be rising out of the hole), another advantage of the broken grain on the top of the plug (now somewhat flattened by driving it in, but still very visible). I'm conservative here - better to leave some extra for the next step than have to repair a plug that breaks off below the wood surface.
Then I take a sharp block plane set fine, and plane off little shavings until it's level; sometimes a little sanding is needed at the end, but often the plane can do it all. Side note: I used to want a chisel plane, thinking it would be necessary for this kind of trimming, but a block plane does just fine, and it's really cool to watch those little round shavings flow out of the plane.
By the way, I've never had much luck with the 1/4" plug cutter in my (granted, cheap) set. There's so little actual wood in the plug that the plugs often fall apart before I can use them, and the side of the plug looks like it was chewed out.
Fred Davis
>To paraphrase the Teenie Boppers . round is so yesterday, if you have a hollow chisel mortiser, try square plugs , you'll like them.
FredD
Bill White
>I use 3/8" for all.
Bill
Thomas S Stockton
>I would agree with what the others say it is usually 3/8" but I would measure the counter sink bit to be sure I have some oddballs in my collection that are something else
Tom
del schisler
>I use 3/8 for mine And i use lot's of #5 and #6 I use a tapper plug cutter The best for that is a match set Veritas brand That is all i will use The plug is tappered and will fit tight You can get them from most supplyers The best del
